» Buyers Guides |
09-03-2008, 09:22 PM
#91 (permalink)
Originally Posted by DAMADMAN
Harley has gone to ****... mine was at .0045 at the end of the pinion shaft, 6000 miles. I just saw an 06 at the wrench getting a whole new lower end. crank scissored and wiped everything out. You would think for a 16,000 dollar bike youd get something a little more.
What caused you to check the runout? Were you having problems? Or, were you changing cams or something? What are you going to do with it?
09-03-2008, 09:30 PM
#92 (permalink)
Iron Butt, SS2000
Originally Posted by mungo
This what you're looking for?
2009 Touring Service Manual Table 3-11
Runout (shaft in case) 0.000-0.010in
Runout (shaft in truing stand) 0.000-0.004in
End play 0.003-0.013in
I need some schoolin. Why would the same crank that has .004" in a truing stand, also have .010" while it is installed?
Is this all about where the run out is measured? What am I missing?
Dyno:
Spare Bike:
09-04-2008, 03:15 PM
#93 (permalink)
This is what it says on TT324.
• Measurements taken on a crankshaft while in the crankcase are used to
determine if further action or inspection are required
Specifications will be higher when measured in the crankcases than in a truing stand
due to bearing run-out, stack-ups, and shaft length / distance from the bearing races.
09-04-2008, 07:31 PM
#94 (permalink)
if cases align properly, and bearing races align properly, there should be NO difference. we used to line lap cases upon motor build, now this is not done.
09-05-2008, 05:57 AM
#95 (permalink)
Iron Butt, SS2000
Fair 'nuff. Thanks, I'd never have imagined the cases would conribute to the problem. Live and learn.
I guess if I was within tollerance while the crank is installed I'd skip the line lap anyway but... How much would a line lap add to the cost of a build? (this sounds like a similar job as a line bore on a car engine, correct?)
Dyno:
Spare Bike:
09-05-2008, 09:45 AM
#96 (permalink)
your thinking is correct, but the cases are made differently now. if you go with timken on both sides-------then you can lap.
11-28-2008, 02:23 PM
#97 (permalink)
Hi All,
Just wanted to let you people know I lost my crank in my 2007 ultra at 5000 miles.
Gene
11-28-2008, 03:16 PM
#98 (permalink)
Moneygreen
Originally Posted by 2007scoot
Hi All,
Gene
Geesh!!!! Now you have an excuse to upgrade it & make it better!!!
Craig G.
11-28-2008, 03:37 PM
#99 (permalink)
Harley paid to install a brand new engine. At the time the engine blew it was built to a 103 inch with redshift 577 cams, thundermax auto tune ecm and a thunderheader 2 into 1 exhaust. I had the kit reinstalled on my new engine.
Gene
11-28-2008, 03:43 PM
#100 (permalink)
Moneygreen
Gene
Humm!!!  Good luck!!!!!
Craig G.
11-28-2008, 10:11 PM
#101 (permalink)
Originally Posted by pittguy
http://www-odi.nhtsa.dot.gov/complaints/ Many owners will complain about thngs dealers say is normal and post here such as heat issues,odd noises etc. But dont post when they had runout problems which many were fixed under warranty early on. Any manufacture has to answer these complaints if they become a pattern. This site cost nothing other than your time. It helps these companys build better,stay out of court fighting lemon laws,maybe helps keep a future or new buyer.But most of all maybe save someones life!
I went to the NHTSA SIGHT and could not find one complaint about crank shafts for any 07 to 09 FHL models. Lots of compaints and recalls for the breaks and fuel canister. some heat complaints but no crank issues reported.
