» Buyers Guides |
06-09-2008, 03:43 PM
#16 (permalink)
Originally Posted by roadchaser
08 HD <--> Mobil 1- 15w-50
As you are now not compliant with the warranty requirements are you betting (== hoping) that you'll have no "oil related" warranty issues (cam bearings/followers), etc?
09-16-2008, 11:19 PM
#17 (permalink)
Originally Posted by muleskinner
A lot of guys on that forum with Harleys are using the M1 15-50 car oil in their bikes, but the M1 V-Twin 20-50 has a lot more moly in it than the 15-50 oil. I also think the 20-50 oil is better in the summer. But thats just my opinion.
muleskinner my understanding is the auto oil 15-50 has more moly in it that is why they dont normally put it in the primmary.
might be ok in engine but I would stick with V-20-50w
07 Heritage, Retired
09-17-2008, 01:34 PM
#18 (permalink)
correct on the moly, but it's still pretty low; I'm not losing any sleep over it.
This is discussed in Mobil 1 V Twin (odd simularity in string titles, eh?). Per a post from Electraglidin':
Code:
__M1_ _VTwin_
Silicon: 9 10
Boron: 228 188
Sodium: 13 3
Magnesium: 43 538
Calcium: 2464 1899
Phosphorus: 1193 1142
Zinc: 1315 1352
Molybdenum: 90 0
- units in ppm
Certified Geezer: 05 Road Glide
DoD #0472
10-19-2008, 07:11 PM
#19 (permalink)
Originally Posted by airmann6
Wondering if anyone is using Mobil One 20w50 V Twin oil in there bike and with what results ? Thanks
I'm using the Mobile 1 20w50 V Twin on my RK. Spectro in the trans and Formula + in the primary.
10-19-2008, 09:51 PM
#20 (permalink)
Have also been using Mobil1 V-Twin in the engine, Spectro in the trans, and Formula+ in the primary. All 3 area Wal-Marts recently quit stocking the Mobil1; and the only indy stocking it want's $12.00 a qt.
Being very serious about the lubricants for my Ultra, I decided to try the Red Line Oil PowerPack Kit from:
www.racerpartswholesale.com
Includes their 20W50 motor oil, the Heavy ShockProof for tranny, and the MTL for primary. They're also throwing in a promotional hat, funnel, and bottle of Fuel Injection Cleaner.
After a few hundred miles, I'm well satisfied with the products. Many riders have suggested the ShockProof Heavy for these cruise-drive 6-speeds, and I have to say it's doing an excellent job; maybe a tad quieter than the Spectro.
HTH's
2007 FLHTCU Ultra Classic
Black Cherry Pearl
Rush 1.75 Exhaust
Ness Big Sucker I
TTS Mastertune
Isolated Drive System
10-19-2008, 11:05 PM
#21 (permalink)
Night Train Darkness
I run it in the engine of my '07, and it lowered my engine temps quite a bit. I used to run it in all 3 holes, but I decided it would be better to use products specifically designed for the primary, transmission, and the engine and not try to use a one size fits all approach. When you think about it, a primary is quite different from an engine. So, I'm still running Mobil 1 in the engine, but I use Royal Purple trans in the transmission, and Royal Purple primary in the primary.
It seems to shift a little more quietly now.
2007 Softail Night Train
10-29-2008, 12:52 PM
#22 (permalink)
Originally Posted by biggerden
I can also tell you that the 15w50 mobil1 will be fine too!I used that many years ago in our drag bikes 86 gsxr1100 that ran low 8's at over 160mph the first season we broke the motor down three times and changed bearings out of guilt there was no signs of wear! 1109cc mtr inj with nitrous never had any clutch issues in three seasons and never had a bearing failure! Good Stuff
I see two Mobil 1 15w50s on the shelf now. One is the original label and the other is the Extended Performance version. Are these 15w50s interchangable ?
Thanks >>>> Inthered
2008 ORANGE/BLACK FXDL, Vance & Hines Slipons, XIEDs, SE Stage 1 airbox
2003 ORANGE Z1000, Yosh Slipons, PCIII, Rohm Advancer, K&N w/stage 2 airbox
10-29-2008, 04:26 PM
#23 (permalink)
MEN,
I have used Mobile One in my Trucks for ever, Great Oil!!, But when it comes to ATV oils And Motorcycle oils ITS (AMSOIL) for me these people has always had there sh!t togteher when it comes to TOY OIL,
Tj
10-29-2008, 09:15 PM
#24 (permalink)
I used Mobil 1 20/50 for about the first 40,000 on this bike. I tore it down at 32,000 and it was like new inside. No scuffs on the cylinders and everything looked like it had a few hundred miles not 32,000. I was impressed and I have torn down a few motors over the years. None of which looked this good. Am now at 68,000 and plan on many more miles. I do run Redline 20/60 during the summer months now.
04 GLIDE
95" 10.5 -1 S&S
TC-2G cams
RB Racing LSR 2 into 1
Ness Big Sucker
10-30-2008, 11:08 AM
#25 (permalink)
Originally Posted by 04GLIDE
I used Mobil 1 20/50 for about the first 40,000 [and] I do run Redline 20/60 during the summer months now.
Why? does the extra '10' make a difference?
DoD #0472
10-30-2008, 06:26 PM
#26 (permalink)
When Im running across the desert and it's 100*I want all the protection i can get.
04 GLIDE
95" 10.5 -1 S&S
TC-2G cams
Ness Big Sucker
11-02-2008, 08:11 AM
#27 (permalink)
I use syn in the wife's bike and it works fine...my bike has an aggressive cam and makes some noise...it also runs hotter...I live in the deep south, low elevation, high humidity, and very hot 5 months out of the year...have better results temp and noise wise with straight 50 conventional oil...just have to keep it below 230* F and change every 2500 miles...imo syn aerates bad and is too thin at operating temp...fine for mild builds but I like straight conventional oil for a hot-rod...will be getting an oil cooler next spring
currently: 08 fxdse2 110", r&r stage 4 heads, se257 cams, 10.7 compression, hp inc 55mm, se injectors, wood 3.25" a/c, supermeg
07 fxdb 96", al taylor "blueprint plus" heads, 37 cams, 9.8 comp, fatcat
05 flhrci 103", SEp heads(cleaned up), se stroker crank, se flattops, 10.7 comp, se 251 cams, roadrage, jagg 6-row
88 xl converted to 1200, dale miller heads, 12.5 comp, se cams, kerker exh, keihin 40mm blade-style carb
11-02-2008, 09:28 AM
#28 (permalink)
Originally Posted by AZFXSTB
Unless the formula has changed thats bass ackwards V-twin has no Moly in it..last breakdown I saw of it. The 15-50 does thats why it slips in the primary more
I run 15-50 in the engine as well
Type F ATF in primary
Mobile 1 75-90 in the tranny
I thought no car oil could have moly in it anymore due to screwing up the cat coverters..
 Nowhereman who else?
