Wheeldock.comAvonTyresPro PadProCharger.comEagleRiderD2MotoBikeBanditLawTigers
Old 08-28-2007, 08:09 PM   #1 (permalink)
hdforme62 is on a distinguished road
07 fxd pigtail behind air cleaner
I installed stage 1 breather assy.today and while removing the old backing plate there was an extra plug that was capped off and anchored to the backside of the backing plate.Does anyone know for what applications this is used for on other models?
hdforme62 is offline   Reply With Quote
Old 08-28-2007, 08:28 PM   #2 (permalink)
I tried to edit the title without much luck.Obviously it should read air
(C)leaner.
Old 08-28-2007, 08:33 PM   #3 (permalink)
03 Roadking's Avatar
03 Roadking is on a distinguished road
That is for the International bikes. They have a door that opens on the back of the air cleaner.
07 FLHX Vivid Black 103 CI
SEAC
V&H True Duals with Ovals
USAF Retired
03 Roadking is offline   Reply With Quote
Old 08-28-2007, 08:44 PM   #4 (permalink)
Makes sense.Goes along with their exhaust.
Thanks!
Old 08-28-2007, 08:47 PM   #5 (permalink)
Premium octane member
TXCHOP's Avatar
Just secure it out of the way where it wont burn or chafe anthing....
03 is right its for the a/c flapper on HDI models.
HILLSIDE CYCLE 117
Hillside custom heads, S/E billet cam plate/oil pump, S/E 4.375 forged crank Darkhorsed, Axtell cyls and pistons, S+S p-rods and roller rockers,S/E CV51 carb, DTT ignition, Black Fatcat w/perf baffle, Pro Clutch,Woods TW9BG cams and KF325 filter
TXCHOP is online now   Reply With Quote
Old 09-03-2007, 06:17 AM   #6 (permalink)
jamsdude's Avatar
jamsdude is on a distinguished road
air temp sensor
where is the air temp sensor located. Zippers says that their breather kit relocates it to a cooler place. Says by relocation of the sensor there is an increase in hp
07 FLHT
Big sucker
T-max
Screaming Eagle slip-ons
Wild one Chubby bars
Stock for now except for the bars
Ride like the wind if you can .................................................. ..................................
jamsdude is offline   Reply With Quote
Old 09-03-2007, 07:42 AM   #7 (permalink)
:. Bones Surgeon :.
ItalianGlide's Avatar
ItalianGlide is on a distinguished road
active intake
that's what the plug is for is for.
We have a small trapdoor in the anterior/inferior part of the airbox, that partializes the intake hole in ts superior portion. It works with a stupid electromagnet and opens up as rev climb, exactly as the other stupid valve on one of the two exhaust does...
Hope this helps
ItalianGlide now proudly rides:
2007 FatBoy, SE A/C, D&D FatCat, Thundermax w A/T (map 391)
ItalianGlide is offline   Reply With Quote
Old 03-25-2008, 06:07 AM   #8 (permalink)
vime's Avatar
vime is on a distinguished road
'07 Air cleaner
hi everybody. I have FatBoy '07 and i just installed the K&N RK-3909 air cleaner. Since I live in Italy, the airbreather backplate has a flap that regulate the intake air (it's a solenoid, so it fully opens or partially closed - 2 only positions).
Afetr having installed the K&N I left unplugged the control of such a solenoid, therefore the "Engine" light is always on on the dashboard.
If I replug the connector (and hold the backplate) the light turns off. So it sounds as the loop of the circuit is under control of the electronics.
I have 2 choices:
1) take the solenoid out of the backplate, plug the connectore and hold it all somwhere (but this would mean to brake the backplate...)
2) shortcut the free-end plug by installing a resistors, but in this case I wonder to know the Ohm and Watt of it...
ANY CLUE?
vime is offline   Reply With Quote
Old 07-06-2008, 02:29 PM   #9 (permalink)
RodrigoOliveira's Avatar
RodrigoOliveira is on a distinguished road
I could use some help also. If anyone has a clue on how to "jump" the sensor...
Actually I removed the street legal muffler's fiberglass and decided to take out the stock filter backplate... hope it works fine...
RodrigoOliveira is offline   Reply With Quote
Old 07-06-2008, 03:55 PM   #10 (permalink)
Scary Paranoid Loonie
route66paul's Avatar
modifying the engine for more airflow could mean that a retune is needed. But we Know nothing of the Brazilian HDs because of the mandated engine modifications.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
Andrew's 37 cam
Atwood's street ported heads
.030 head gasket
SuperTrapp Supermeg 2in1
Steve Handy dyno map
"43" points cover
Custom after Crash
TRW rear mount
Just sayin..........Dumbasses
Old 07-07-2008, 07:33 AM   #11 (permalink)
hellboundpig is on a distinguished road
I have 2 choices:
ANY CLUE?
vance& hines make a adaptor kit for the aircleaner and the active exhaust valve part no v31001 try that bro.
hellboundpig is offline   Reply With Quote
Old 07-23-2008, 04:35 AM   #12 (permalink)
vime's Avatar
Hi,
looking into other forums and playing with multimeter in that electrical circuit, I set by myself an electric adapter to bypass the airintake flap coil, which if disconnected throws an error on the dashboard.
It works fine since last September. If anybody interested, let me know I'll give you more details. It's cheaper than V&H or any other solution on the market.
