» Buyers Guides |
06-10-2007, 10:16 PM
Screamin Eagle Triple Platinum plugs- Pre Gapped?
I just purchased the Screamin Eagle Triple Platinum plugs, 32996-01 for my 07 Road King. Does anyone know if they are pre-gapped out of the box? If not, what is the proper gap for these plugs?
06-11-2007, 07:36 AM
I use them ( have for 10,000+ miles) , and according to the wrench they are pre-gapped . I had no issues right out of the box
May the road ahead be long , and trouble free
06-11-2007, 07:57 AM
Thanks for the reply. I'll put them in and let everyone know if I have any issues.
06-11-2007, 11:48 AM
Plugs
Don't trust any plug to be pre-gapped.
We have seen all the u-groove, split-fire snakes tongue, multiple ground strap stuff.
What we have seen is goodness with NGK Iridium's recently.
Palmer Bros.
Hillside Motorcycle & Machine
V-Twin Performance Center
Munnsville, N.Y.
315-495-6650
www.hillsidecycle.com
"Repairing Broken Torque Curves Since 1982"
Land Speed Record Power
06-11-2007, 11:55 AM
Have you got a part number for that NGK plug...thanks...
06-11-2007, 11:58 AM
Plugs
NGK # DCPR7EIX
Palmer Bros.
Munnsville, N.Y.
315-495-6650
06-11-2007, 12:08 PM
Is there maybe an auto parts store that might have these in stock...? Thanks Andre'
06-11-2007, 12:43 PM
Plugs
I would have to believe that.
Palmer Bros.
Munnsville, N.Y.
315-495-6650
06-12-2007, 09:59 AM
sparkplugs.com
06-17-2007, 12:37 AM
NGK Iridium Plugs
Originally Posted by Hillsidecycle.com
NGK # DCPR7EIX
Are these plugs worth using?????? Are they better than the stock Harley plugs or the preffered Autolites?
06-17-2007, 07:04 AM
I used the Harley triple platinum plugs right out of the box. No issues. My preference is always to use genuine Harley parts in my Road King.
09-05-2007, 03:30 AM
NKG Iridium Performance Spark Plugs
The NKG Iridium Spark Plug P/N for 2001 - 2008 Twin Cams is:
NGK # DCPR7EIX (Stock No. 6046).
They are available through any Car Quest auto parts store (CA) for $7.98 ea.
I spoke to NGK's Tech Support and was told these are the best, "Premium Performance" spark plugs available and far exceed the performance of any platinum plug.
I also noticed that our local HD Dealer has NGK Platinum plugs on the shelf for 13.99 each (lesser performance than NGK Iridium plugs).
CAUTION: NGK confirmed that the DCPR7EIX plugs come pre-gapped at 0.032 from factory. Twin Cam motors require a 0.040 gap.
NGK said not to use any spark plug gapping tool that applies direct pressure on the thin, Iridium (center) rod. Any forcefull prying against the Iridium rod will result in S/P electrode damage and plug failure.
09-05-2007, 05:24 PM
Good OL NAPA
Auto parts, carrys most NGKs, priced right , too.
I had a noticibly positive difference in the seat and idle behavior over HD plugs and I am not using the Iridium.
NGK .040 gap is for stock compression, .032 (I believe) is for around 10.25. adjust slightly higher comps.
My compression is 9.6, I gap at .036 one cold from stock.
go to go
