I installed a V and H header, Rinehart slip ons, screaming eagle exhaust and fuelpak on my 2010 Electra Glide Classic. Tried to start it - motor turned over well but wouldn't fire. I removed the FuelPak and had the same result. I checked the fuses and found the ECM fuse blown. Repkaced the fuse and as soon as I hit the RUN button it blows every time. I also have an extra connector other than my starter wire coming off the positive side of the battery. Don't know where to start to diabose....
Start visually checking the wires in the loom attaching to the ECM, space is very tight behind that side cover where it resides. Chances are the insulation got worn off one of the wires and is grounding to metal.
Best of luck in tracing down this problem, I and others will be ready to give advice and moral support.
Hang in there, I know it gets frustrating and time consuming.
Related Threads
V-Twin Forum
2.7M posts
146K members
Since 2001
