09-28-2012, 02:23 PM
.A.R.M. RIDER
Engine Upgrade/Swap Question...AGAIN
OK, so I have an '09 FLHRCI, the minute it was delivered I had a 110"
SE Big Bore Kit and Power Commander PCV with Autotune installed, after a lifter failure at 17000 mi, I had a Fueling BulletProof CamChest Kit put in, 630 cams,Race Series Lifters&Pushrods, BeeHive Valve Springs,and a Fueling oil pump. at that time the dyno said 108/108 with V&H True Duals. Since then I switched to a D&D Fat Cat w/wrapped louvered baffle. Now along comes the 120R... I'm looking for more hp/tq in a reliable package, so do I put more $ into my current setup (if yes what suggestions) or just order the 120R and be done with it. Thanks in advance!
09-28-2012, 02:52 PM
Thats alot of money for only 10 inches ....
10-07-2012, 08:20 PM
OK, so I have an '09 FLHRCI, the minute it was delivered I had a 110" SE Big Bore Kit and Power Commander PCV with Autotune installed, after a lifter failure at 17000 mi, I had a Fueling BulletProof CamChest Kit put in, 630 cams,Race Series Lifters&Pushrods, BeeHive Valve Springs,and a Fueling oil pump. at that time the dyno said 108/108 with V&H True Duals. Since then I switched to a D&D Fat Cat w/wrapped louvered baffle. Now along comes the 120R... I'm looking for more hp/tq in a reliable package, so do I put more $ into my current setup (if yes what suggestions) or just order the 120R.
IMHO, you should have orderd the 120R when the lifter failed. Those dyno numbers are not impressive for a 110"; there are 95" motors putting up those kind of numbers. Order the 120R; you should see 125HP/135TQ out of the box with the true duals.
11-23-2012, 07:50 AM
What kind of power did it make after you changed exhausts ? I have true duals and my buddy's have d&d's, they seem to have more zip down low but out on the road, mine seems a little stronger.
11-23-2012, 08:20 AM
I just had a 120R installed and got 145/141 with a few light massages in place. True duals and it hauls azz! Dyno sheet is in the dyno section if you'd like to see the numbers.
11-30-2012, 03:35 PM
S&S 124" for 09 up baggers
We make a 124" for your 09, comes with a warranty, EZ start Gear Drive Cams, S&S Oil pump which has 30% more oil flow than the SE Pump, Adjustable Pushrods. All for about the same price as the 120R, We also have our Throttle Hog, DBW in 58mm, 66mm, 70mm throttle bodies. These engines have great low end torque and top end power.
11-30-2012, 03:40 PM
Axe Man
The warranty alone would sway me in the direction of the S&S motor.
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
11-30-2012, 05:03 PM
Your lifter failure was unfortunate and probably unforeseen, but putting a Power Commander on that motor and not getting a "REAL" tune probably contributed to the poor dyno numbers more than anything else. I'm not a big fan of anything "Power Commander" or anything AUTOTUNE...There is no substitute for a human there IMHO.
It's also been my understanding that true duals were power robbers and a good 2-1 generally will kick there ass on a dyno.
2005 Road King Classic FLHRCI
95" w/ SE Flat Tops
CAMS HQ-34g's
HEADS/CYLINDERS Head Designs By Dewey, Edgewood, WA
TTS MasterTune
Built by Me
93.12 HP/107.06 TQ (uncorrected)
12-06-2012, 03:21 AM
Why? A warranty does you NO JUSTICE when you're on the side of the road. I never could understand this mentality. I would, and still do, place zero stock in a warranty.
Now, let that same company/vendor publicly post their return, breakdown, poor quality issues, busted parts percentages and they may earn my business. But NONE of them will.
Warranties are just sales gimmicks. I'd rather buy from someone that can show quality and low issues than someone that flies a great warranty.
Lets see...motor takes a dump on me. Leaves me stranded. leaves my bike down for XX months. Vendor fixed it. Big deal.
Bottom line.....sell quality and we don't need to rely or make buying decisions on a warranty.
like I said....warranties are sales gimmicks.
| Sponsored Links |
