Harley engineering drop the ball on 96 cu./in. motor? : V-Twin Forum: Harley Davidson Forums
Old 01-15-2011, 05:36 PM   #1 (permalink)
windrider08 wants to know Dino or Syn?
I believe that harley engineering really dropped the ball on the 96 cu./in. motor.
1. engine high temp. issue 2. weak crank issue 3. low to mid range rpm vibration issue.
I did not have any issues like this with any of the 88 cu./in. motors that I have owned.
Does anyone know why harley went to the 96 cu./in. motor anyway, why mess with something that runs great !
windrider08 is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 05:47 PM   #2 (permalink)
Discarded Crew Member
ktwillys's Avatar
ktwillys wants to know Dino or Syn?
the only thing that the 88's dont have is the over heating issue..
the flywheel is still a piece of crap and cannot take even a mild workload before it fails..
and the 88's have exactly the same vibration issue..
it is not the 96 that is such a big issue..
IT IS HARLEY DAVIDSON..... they make crap...
the majority of the harley now is made in other countries than the USA...
so you are buying just as much forgien crap as if you bought a Honda or a Kawi....
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DisCarded Crew
04 FLTRI
SE Welded/Balanced Flywheel
103 CI
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
T-Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 05:49 PM   #3 (permalink)
berserker's Avatar
berserker is still riding a stock bike berserker is still riding a stock bike berserker is still riding a stock bike
I am nervous, I got a noise on my 07, only when moving , replaced front bearing, and adjusted belt. Sounds like its coming from the primary or tranny. I hope its not a result of the chugging and vibration in the 07, without the IDS.
I always said bad idea to buy first year of something. But I figured they couldn't screw up a 96" and 6 speed.
berserker is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 05:51 PM   #4 (permalink)
berserker's Avatar
WR, you have an 08, what vibration are you talking about? I have an 07 without the IDS. I wish I would have bought a 08. 6 gallon tank, shorter then the new ones. Seems the 08 may be a little better on heat then my 07 too.
Old 01-15-2011, 05:54 PM   #5 (permalink)
nvsteve wants to know Dino or Syn?
I hear ya zerk. I get an occassional whine from the primary. I installed the IDS but still think I'm running on borrowed time.
nvsteve is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 06:01 PM   #6 (permalink)
berserker's Avatar
When I got back from AK, the whine was real bad, to the point the bike has been grounded since July. Nice spending 20k on a bike to have it sit. My next step is open the primary and see if I can see anything. Then I am wondering about the tranny bearings. Also not being a profesional, unless its really bad, I may not be able to tell if its bad.
Bike only has 37k on it.
Old 01-15-2011, 06:13 PM   #7 (permalink)
Hey Berserker,
my 08 flhx did not have as much vibration as the 09 fxdl that I now have.
Seems that I have to keep the rpm at least at 2500 to 2600 rpm when driving around town to smooth things out. The only time I think the 96 runs well is from 70 mph. and up.
Old 01-15-2011, 06:34 PM   #8 (permalink)
Basic Hog Rider
xxxxxkwizard wants to know Dino or Syn?
As far back as I can remember, the best Harley was one that had been torn down and put together correctly with all the bugs taken out. This is still true, and when you get em right, they are awesome.
xxxxxkwizard is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 07:05 PM   #9 (permalink)
Kwizard, you are so right when they come together they are awesome !
I do love my Harleys!
Old 01-15-2011, 07:26 PM   #10 (permalink)
motorheads5's Avatar
motorheads5 is reading this now saying WTF is this?
I've got no complaints about mine.
motorheads5 is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 07:42 PM   #11 (permalink)
Nitram_b4's Avatar
I got 50k on mine, no problems
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 01-15-2011, 11:38 PM   #12 (permalink)
berserker's Avatar
Originally Posted by windrider08 View Post
Seems that I have to keep the rpm at least at 2500 to 2600 rpm when driving around town to smooth things out. .
I only run that low when I am coasting, and want to keep my pipes quite. Other then that you are lugging the hell out of it.
Old 01-16-2011, 01:46 AM   #13 (permalink)
Advanced76 wants to know Dino or Syn?
Really come on?
You bought a 45 degree, pushrod, aircooled vtwin, and now your gonna bytch that it vibrates too much, runs too hot and make too much noise? Your kidding right? Trade it in and go get your Goldwing.... And whine over on their forum about all the big bad Harleys guy with there broken cranks and what not...
12 FLHTCU
Advanced76 is offline   Reply With Quote Quick reply to this message
Old 01-16-2011, 06:19 AM   #14 (permalink)
ultraplusrotax's Avatar
ultraplusrotax wants to know Dino or Syn?
LUGGING !
Why would anyone ride at 2500 rpm ? nothing to be gained.
My 96 behaves well, it is not "warmer" than my 88.
The only thing that might go wrong could be the compensator I guess.
ultraplusrotax is offline   Reply With Quote Quick reply to this message
Old 01-16-2011, 06:25 AM   #15 (permalink)
VTF Hang-around
Scrubs's Avatar
Scrubs is reading this now saying WTF is this? Scrubs is reading this now saying WTF is this?
Also. EPA restrictions ain't helping us or the MoCo either...jus' sayin'
Scrubs
'06 Softail Night Train
Stress In / Solace Out
Scrubs is offline   Reply With Quote Quick reply to this message
