'09 TC96B hard starting issue : V-Twin Forum: Harley Davidson Forums
Old 06-23-2010, 12:17 AM   #1 (permalink)
Robo's Avatar
Robo wants to know Dino or Syn?
Sometimes when I start my '09 Night Train it sounds as though it is an air compressor. Warm, cold, it really doesn't matter; it is an occasional issue. The only mods are Zipper's open element A/C, Cycle Shack slip-ons, and (non-dyno) tuned with a TTS.
It "sneezes" a small white mist through the air cleaner sometimes when I start it. I was wondering if I needed to run a couple of V-tune runs since the weather made a 20 degree change on average since I got the last V-tune run done. It ran REALLY well when the ambient temperature was 20 degrees cooler, what do you guys think may be the problem?
Soul Brother No.1
Robo is offline   Reply With Quote Quick reply to this message
Old 06-23-2010, 12:22 AM   #2 (permalink)
Ride Free
BoomerBob wants to know Dino or Syn?
I agree. A couple of V-Tune runs might fix it. If not; then a regular Dyno Tune by someone good with the TTS/SERT.
It sounds a bit like the timing is off too.
BoomerBob is offline   Reply With Quote Quick reply to this message
Old 06-25-2010, 02:16 PM   #3 (permalink)
JOKERS IMPALA's Avatar
JOKERS IMPALA wants to know Dino or Syn?
Having same issue and no real answers LMK if you find anything out
http://www.v-twinforum.com/forums/tw...gh-intake.html
2009 Night Train
Roland Sands A/C
Black Big Shot Staggereds
PCV & Autotune
Andrews 54H Cams
S&S 107" Big Bore
SE Clutch Spring
Battastinis Grips
Stage 4 Heads by Flo-Tec Racing
2014 Street Glide Special Charcoal Pearl
JOKERS IMPALA is offline   Reply With Quote Quick reply to this message
Old 06-25-2010, 09:37 PM   #4 (permalink)
WVULTRA's Avatar
WVULTRA wants to know Dino or Syn?
Robo:
Curious as to what map your using that's already VTuned. Maybe AE176?
Sounds as though you might be a little rich on the low end, hence the "mist" coming out the a/c. Have you made any changes to the Cranking Fuel Table?
Doubt if it's a Timing issue as the ECM is coded to use "0" Spark Advance while cranking.
2007 FLHTCU Ultra Classic
Axtell Pro Street 107"
Axtell Stage II Heads
SE Breather/Zippers Max-Flow
Rinehart True Duals
TTS Mastertune
'08 Brembo Conversion
WVULTRA is offline   Reply With Quote Quick reply to this message
Old 06-25-2010, 10:07 PM   #5 (permalink)
Robo's Avatar
Originally Posted by WVRDKING View Post
Robo:
Yes, that's the one that was used.
I only changed the parameters in the "Help File", so no; the Cranking Fuel Table was not adjusted. I considered that it might be rich there, also.
I was wondering if barometric pressure differences affected EFI engines as much as they do carbureted ones (run a little differently based on ambient air pressure). Would this have anything to do with it?
Soul Brother No.1
Old 06-25-2010, 10:23 PM   #6 (permalink)
WVULTRA's Avatar
Yes, pressure and air temp changes do affect the EFI bikes; but the MAP and IAT Sensors should make appropriate adjustments as needed.
Might want to do a few additional VTune rides, and make sure your map is set up properly for VTuning. Temp/pressure differences should be automatically accounted for, and VTune H-D should yield corrections if you've recorded correctly with Data Master.
After warming the bike up, a good recording while idling/slightly increasing the throttle just sitting still will give you an idea if the idle/closed throttle VEs are too rich. Look closely at VTune H-D's results after you've collected the data.
Without seeing your latest map that's loaded in the ECM, kinda hard to guess where your rich at.
Rinehart True Duals
TTS Mastertune
