ProCharger.comCycleGear.comDiamond Bar ChoppersPro Pad
American Side Road Cycle
Motorcycle.comFuel MotoBikeBandit
American Side Road Cycles
Old 11-04-2009, 05:45 AM   #1 (permalink)
Roadglide2003 is on a distinguished road
No start after washing???
2007 Roadglide mostly stock , after washing bike, it will not start. Ihave to blow dry the intake area, then it will start up and run flawless. It also was hooked up to computer and threw no codes, all showed ok. Any ideas??
Roadglide2003 is offline   Reply With Quote
Old 11-04-2009, 07:28 AM   #2 (permalink)
LADave is on a distinguished road
If you used a pressure washer, that could've caused it. They will put water into areas that shouldn't be wet. Don't use 'em for washin' your bike...
May have pushed water into a connection, blow-drying it cleared it out...
Everyone wants to go to heaven,
Nobody wants to go now...
1987 FXRS-SP
.005" over 80-Inch, Andrews EV27 Cam
S&S "E" Carb - Ultima Single Fire Ignition
Manley Stainless Steel Valves & Crower Springs
Ultima Single-Fire Ignition
2-into-1 pipe (might be an LSR)
LADave is offline   Reply With Quote
Old 11-04-2009, 09:34 AM   #3 (permalink)
Just a garden hose used! We can make it do it any time, then blow ot off and it will start. No codes is the part that is weird.
Old 11-04-2009, 09:47 AM   #4 (permalink)
Premium octane member
TXCHOP's Avatar
Dont have a powercommander do you?
Check the ECM connection for water...
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
Old 11-04-2009, 10:49 AM   #5 (permalink)
Its got the Fuel Pak.
Old 11-04-2009, 10:58 AM   #6 (permalink)
TXCHOP's Avatar
Well, close enough...lol
Check the ECM connection for water. Seen it happen before. If it is wet, dry out good and you should be fine. If thats not it.............?
Mikuni HSR48
Black Boarzilla
Old 11-04-2009, 11:21 PM   #7 (permalink)
The Anti-RUB
petrock's Avatar
A garden hose with a spray nozzle can produce alot of pressure. Same with an open ended hose with your thumb over the end. Both can easily cause problems.
You could have easily flooded the intake with water (depending on the A/C you have installed). If air can't get in, the bike won't start. The ECM theory is also possible.
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 11-04-2009, 11:53 PM   #8 (permalink)
FOG
trooper113's Avatar
trooper113 is on a distinguished road
If you aren't doing so, use dielectric grease on all your electrical connections.
trooper113
NRA Endowment Member
AMA Member
trooper113 is offline   Reply With Quote
Old 11-05-2009, 02:05 AM   #9 (permalink)
hdpunk is on a distinguished road
here is an idea.....stop using water cause it can get into fuel packs, air cleaners and intakes
hdpunk is offline   Reply With Quote
