Had this problem myself a while back - it was the connector for the regulator (the one that is mounted under the regulator). Cleaning, treating and reseating it worked. Worse case, put a slight twist in the pins to ensure positive contact. Of course, the quickest way to check is to squeeze the connector tighter together while idling and see if the headlight brightens or if your voltage climbs up to the 14.7 range.
 2005 FLHT
95" KB 9.25 pistons (0.30 over)
9.7:1 static with milling
Big Boyz heads
Cometic .030 Head Gasket
Andrews 37g cams
180psi ccp
HD SE Billet camplate and pump
Mikuni 42 carb (22.5 pilot/160 main/50 accel/98 needle)
S&S IST ignition
M6 Tensioner
SE HD Clutch w/EZ Pull Ramp
Throttle-up Touring-Stabilizer
Fullsac Duals
Wild Pig mufflers with Rush 2 1/4 inch baffles
