Heat
I have "searched" but could not dig through all the info to find what I am looking for. I think oil temp runs around 230 degrees, but where is the correct spot to "shoot" the temp, the bottom of the motor? oil filter? Checking temps on an 07 Street Glide and 10 Wide Glide both 96" motors. What would be a normal temp of the heads shot at the spark plug area? How much does the temp change between front and rear cylinder? I would use an 80 degree day as a base to work from. Thanks for any help I know this is beating a dead horse, but it's new ground for me.
