RRcycles.comMotorcycle.com Classifieds!JardineProducts.comCycleGear.comCustom DynamicsPro PadMotorcycle-Communication
Leslie Kay'sMotorcycle.com
Old 10-06-2009, 04:53 PM   #1 (permalink)
jumiem is on a distinguished road
Hi. I'am new and I need help.
I would like to say hello to everyone And I need a little help. I have a 2007 Road King with a 96" engine. I installed a Woods TW6-6 cam with a +4 gear. When I raise throttle from idle to around 2000 rpm I get a popping out of the exhaust on the front cylinder.It will not do it all the time. Any help would be nice.
jumiem is offline   Reply With Quote
Old 10-06-2009, 05:57 PM   #2 (permalink)
Pebble Cruncher
Rockbiter's Avatar
Rockbiter is on a distinguished road
I would suggest you get the bike tuned by a competent tuner.
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote
Old 10-06-2009, 07:57 PM   #3 (permalink)
Indianspringsaz is on a distinguished road
Dont do any riding until you get that tuned.
07 Road King Standard
GMR 107 with Andrews 54 cams
D&D Fat Cat
Big Sucker
SERT 107/115
Neighborhood Amsiol Dealer
Indianspringsaz is offline   Reply With Quote
Old 10-06-2009, 08:07 PM   #4 (permalink)
Old married guy
vindex1963's Avatar
Welcome and please go here and tell us a little about yourself.
http://www.v-twinforum.com/forums/my-story-beginning/
2009 FLHTCU Ultra Classic
Vance & Hines Fuel Pak
Vance & Hines Slip-Ons
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 10-07-2009, 05:56 AM   #5 (permalink)
I'am going see a tuner today and I will post when I get back home.
Old 10-07-2009, 08:52 AM   #6 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
I realize this may be a little too late but... I hope you have done your research on that tuner. Lots of guys call themselves tuners & will take your money, few actually know how to do it right and will take the time to do it right.
Old 10-07-2009, 09:10 AM   #7 (permalink)
The tuner I'am going see is ok. I used him 2 years ago.
Old 10-07-2009, 10:02 AM   #8 (permalink)
mike cats? he is a good tuner. and knows woods stuff well.
Old 10-09-2009, 11:57 PM   #9 (permalink)
bigbluff is on a distinguished road
Ummm... is it possible the front cam is a tooth off in timing?
Some people are like Slinky toys...not good for much of anything, but it gives great pleasure to push them down the stairs.
bigbluff is offline   Reply With Quote
Old 10-10-2009, 07:49 AM   #10 (permalink)
You may be right . I will pull it apart too check it.
Old 10-10-2009, 10:31 AM   #11 (permalink)
strokerjlk's Avatar
does it hiccup then pop? if so it is lean in that area.
no way around buying a tuning device and tuning it with that set up.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
strokerjlk is online now   Reply With Quote
Old 11-14-2009, 08:01 AM   #12 (permalink)
Sorry it took so long to reply,but I will start from the the top again. I have a o7 with 96 engine,se air cleaner,vh true duals,vh oval mufflers and commander.I had it tuned and it was 75.88 power & 93.42 torque. I installed a Woods TW6-6 cam And a +4 gear. Now it was tuned by the same guy and it shows 72.17 power and 92.27 torque. he said the mufflers are the trouble.Maybe I have to much cam.It pulls from 2000rpm to 4000rpm and stops at 72 hp and stay flat to 5500 rpm.
Old 11-14-2009, 09:24 AM   #13 (permalink)
Axe Man
BVBOB's Avatar
So if I read this correctly the cam/advance gear setup actually lost power?, how do the torque curves compare? Would be interesting to see the difference with a decent exhaust, chances are the stock head pipes and cheap slip- ons would perform better.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
Old 11-14-2009, 03:11 PM   #14 (permalink)
HogBag is on a distinguished road
I went through something similar with my 54h cams and found out it was the lifters giving up. I had my motor torn down twice by two Harley dealers trying to fix my crank cases leaking oil and they both missed the bad lifters.
HogBag is offline   Reply With Quote
Old 11-14-2009, 03:33 PM   #15 (permalink)
These are new lifters I installed with the cams.
