Bub EnterprisesLeslie Kay'sJardineProducts.comFuel MotoCycleGear.comPro Pad
Pro Pad
Old 10-01-2009, 10:47 AM   #1 (permalink)
Bandit111 is on a distinguished road
103 kit using oil ..?
Installed a 103 BB kit , 101 hp & 115 TQ 7000 miles ago. Engine runs great but have noticed it has been using some oil . 1600 miles and it is down about a 1/3 on the dipstick . Just wondering if that is something I should be worried about . Or is that just the nature of the beast ...????
Thanks for your time on this issue.
Bandit
Bandit111 is offline   Reply With Quote
Old 10-01-2009, 10:28 PM   #2 (permalink)
cmueller is on a distinguished road
Check compression, both cyl should be within about 5 lbs. If varies more, squirt a few drops of oil in each cyl crank engine a few turns and retest. Also - ground spark plugs to prevent blowing coils. Check plugs for oil fouling.. Also check breather ports into air cleaner, excessive oil buildup.
2007 Wideglide
SE 103 BB - flat tops .030
Zippers 577 HS
Samson BG3's
stage 2 heads 1.9 in 1.610 ex.
S & S HL2T lifters.
Big Sucker & cover
PCIII USB
HD Oil cooler
LMR-002
Welded crank - Timken conversion
cmueller is offline   Reply With Quote
Old 10-02-2009, 01:02 AM   #3 (permalink)
Shed is on a distinguished road
Rings may not have seated 100% go and give the bike a hard run using all the rev range then drain the oil and try something like Amsoil.
I have found HD oil evaporates rather fast.
Shed is offline   Reply With Quote
Old 10-02-2009, 07:46 PM   #4 (permalink)
qtrracer is on a distinguished road
I wouldn't worry too much 1/3 of a quart in 1600 is not excessive but if it starts to use more like 1/2 in a 1000 miles start investigating!
08 SG 103" SE MVA Heads SE 10.5 Pistons SE 251 Cams SE 58 mm TB RB Racing 2-1
qtrracer is offline   Reply With Quote
Old 10-05-2009, 11:40 AM   #5 (permalink)
Thanks !! Talked to my tuner and he said that it should be fine !
Bandit
Old 10-05-2009, 12:54 PM   #6 (permalink)
xtractor's Avatar
xtractor is on a distinguished road
Yep. My new 103 build did same thing during break-in. I now have about 13,000 hard miles on it this season and it does not burn a drop.
xtractor is offline   Reply With Quote
Old 10-10-2009, 04:36 PM   #7 (permalink)
bigbluff is on a distinguished road
If you are running dino for oil, then it will evaporate faster. Running synthetic, like Harley's Syn3 or Amsoil, will improve that.
Some people are like Slinky toys...not good for much of anything, but it gives great pleasure to push them down the stairs.
bigbluff is offline   Reply With Quote
Old 10-11-2009, 09:07 AM   #8 (permalink)
Coolmaker's Avatar
Oil evaporate????????????????????????????????
06FLHRCI
Old 10-11-2009, 07:51 PM   #9 (permalink)
Certainly! All liquids will turn to vapor at some temp.
Dino (oil made from dinosaurs) evaporates at a lower temperature which is why you will use it faster than synthetics which evaporate at a higher temperature.
Old 10-11-2009, 08:05 PM   #10 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
Best answer.
Old 10-11-2009, 11:21 PM   #11 (permalink)
Coolmaker's Avatar
No motorcycle will get hot enough to "Evaporate" oil.....
06FLHRCI
Old 10-13-2009, 06:34 PM   #12 (permalink)
Regardless, dino goes somewhere, somehow, and is lost where synthetics don't seem to go and therefore are not lost.
I assumed it was because of a difference in their behaviors in a high temperature environment... I don't know at what temperatures the two oils vaporize, but the temp in the exhaust port of our Harley engines gets over a thousand degrees F and that is absorbed into the head which has plenty of oil circulating through it, helping to cool it along with the air blowing past the outside. The oil in the heads gets mighty danged hot and I suspect that it is in that environment where the dino gets lost and the synthetic survives. But that is the surmizing of an old man who has learned that I don't have to top off the synthetic oil when I have to top off dino fairly often.
Maybe one of the smart guys (of which I am obviously not) could chime in and explain.
