CycleGear.comSportbikeTrackGearMotorcycle.comPro PadBikeBandit
Motorcycle.com Classifieds!RRcycles.comMotorcycle-Communication
Diamond Bar Choppers
Old 09-23-2009, 04:19 PM   #1 (permalink)
unhcp is on a distinguished road
idle
i let someone ride my bike the other day and he ripped on the throttle and now it idle's too low, i have tried adjust the cables and tension but still way too low, it's has stalled a few times
any ideas?
07 electra glide = fi
unhcp is offline   Reply With Quote
Old 09-23-2009, 04:37 PM   #2 (permalink)
Altered States
Waffen's Avatar
Waffen is on a distinguished road
Year, model, carb or injected???
W
RULE 5: "Ridicule is man's most potent weapon."
Saul D. Alinsky
No mercy, no compassion, no remorse.
Waffen is offline   Reply With Quote
Old 09-23-2009, 07:44 PM   #3 (permalink)
Old 09-23-2009, 08:18 PM   #4 (permalink)
My Pig Flies....
MaloloJoe's Avatar
MaloloJoe is on a distinguished road
There's got to be more to the story. The cables should really not affect the idle. The ECM should be controlling the idle speed via the IAC.
2007 Road King Custom
MaloloJoe is offline   Reply With Quote
Old 09-24-2009, 08:00 AM   #5 (permalink)
I had a similiar problem and the cables have nothing to do with idle speed ecm controls it. Pull your air filter out make sure its not real dirty and get some throttle body cleaner (not carb cleaner) clean your throttle body very well especially a small hole near the butterfly it fixed my low idle,also make sure and cover anything the cleaner might get on. This may not be your problem but it cant hurt...
Old 09-24-2009, 08:09 AM   #6 (permalink)
Dave63's Avatar
If he bottomed the throttle out, HARD, he could have bent something, or affected the IAC. I agree in that the ECU controls the idle speed, but a base idle (mechanical) is set, in conjunction with the ECU. The only other issue that would affect the idle would be the TPS. Are the screws loose or does it look like it's moved at all?
I gotta admit, it sounds strange.
Dave
Old 09-24-2009, 08:24 AM   #7 (permalink)
sporty952 is on a distinguished road
any ideas?
A bunch of whinin' & complainin' should help.
Then next time he won't ask, and if you offer
he won't accept. Then you can mutter things
about his mother under your breath...
-W
sporty952 is offline   Reply With Quote
Old 09-24-2009, 10:08 AM   #8 (permalink)
Krayven Sumhead is on a distinguished road
Try cleaning the IAC butterfly with some brake clean. Several threads on this subject.
Krayven Sumhead is offline   Reply With Quote
Old 09-28-2009, 11:44 AM   #9 (permalink)
fixed
i adjusted the cables and everything is back to normal!
Old 10-06-2009, 08:57 PM   #10 (permalink)
Well , you should be able to take the cables off and it should still idle. If you brought the idle back through cable adjustemt via butterfly opening you problem still exists. You've just worked around it and fooled the system. Problem is usually the iac motor, connections or just crudded up with carbon in the port.
Ron
