09-16-2009, 04:49 PM
how many cubic inches????
i just recieved my th400-6 cams from bob woods for my 09 ultra, my heads are going to scott at hill side cycle for stg-3 work ,and woods springs, i was thinking about hillside boring cylinders to 107 cuin, but i am also thinking about 103 cuinch, is there that much power difference between the different sizes of cylinders? vs longevity???????
thanks
09-16-2009, 05:06 PM
mooooving out!
Yes, they should be worth it, it doesn't cost much more, if any.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
09-16-2009, 05:09 PM
XLIII
thanks
They're boring stock cylinders to 107?
Dave
I mock, therefore I am.
09-16-2009, 05:47 PM
Bore them to 107".
D&D Muffler Bearings
Andrews Piston Return Springs
09-16-2009, 06:26 PM
The story of my life!
You should have that decided before you have the heads done.
09-16-2009, 07:16 PM
 you are building backwards. scott wont know how to work the heads till you decide the cubic inch. makes one question how you decided the cams??????
09-16-2009, 07:55 PM
I run the 400-6 in my 103. Great cam. My heads are done, roller rockers, etc. Nice pulling power.
2008 FLHTC, 103"
114ft/lbs Torque, 118 Hp
09-16-2009, 10:42 PM
well dont you do the heads according to the cam?? thats what bob woods and i talked about displacement isnt as important as the heads. pick a cam do the heads with the correct piston design. i.e. cast/forged/compression??? hmmmmm?????
09-17-2009, 12:07 AM
mooooving out!
Displacement is not as important as the port on the heads, but the sizing of the combustion chamber does matter here.
Yes, the 107 size cylinders for a 96" engine is the same as the 98" bore for an 88" engine.
43%er
HQ575 cams
.030 head gasket
"43" points cover
TRW rear mount
09-17-2009, 04:54 AM
that is correct.......but i would not use the same ports/valves or chamber on a 95 as a 117.. Scott needs to know 107 or 103 for setting up the pistons....
Broke Down Money Pit....
09-17-2009, 10:26 AM
There's no replacement for displacement ;-)
09-18-2009, 12:10 PM
XLIII
That workin' out any better than the 98 did on the 88s?
Dave
09-22-2009, 06:15 PM
Nothing wrong with boring stock cylinders to 98".
PS go with the 107
Hillside 98" Small Bore Kit
Stage III Heads
Stock Throttle Body Bored to 46.5mm
Hillside Air Filter
Woods TW-6G cams
S&S Adjustable Pushrods
D&D Fatcat (standard baffle)
Barnett Clutch Spring
