CycleGear.comProCharger.comMBO EnterprisesRRcycles.comJardineProducts.com
Motorcycle-CommunicationDan Vance Racing
Old 08-31-2009, 10:03 AM   #1 (permalink)
bluecoat is on a distinguished road
left muffler cool enough to touch
My 3900 mile 08 electra glide left muffler is cool enough that I can touch it with my bare hand after a 30 mile ride, header coming off the back cylinder is plenty hot. The right muffler is too hot to touch. I know the cross over pipe delivers more exhaust to the right side but is this normal? I have put about about 1000 miles on the bike, my first Harley. In the old days I would say it is a clogged carb but this is fuel injected. One local dealer says it is okay the other says bring it in for a look see. Anyone else run into this? Can't really see any performance issues, everything is stock except the Rinehart slip ons. Thanks in advance....
bluecoat is offline   Reply With Quote
Old 08-31-2009, 10:43 AM   #2 (permalink)
killer sperm
Milehog's Avatar
Milehog is on a distinguished road
Tis normal. In fact you may want to moniter the left side muffler for rust buildup inside. If your slip ons are symetrical you could swap them from side to side annually.
I'm running SuperTrapp slip ons on my '05 EG and have six discs on the left side and eighteen on the right. The headpipe puts out that much more exhaust out the right side.
I pulled the fiberglass packing out of the left muffler 'cause it wasn't drying out and causing corrosion even though my shortest ride is twenty miles.
xxxxxxxxxxxxxxxxxxxxx
Milehog is offline   Reply With Quote
Old 08-31-2009, 10:45 AM   #3 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
it is for decoration only....
it will rust out before it gets any soot in it....
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote
Old 09-01-2009, 04:36 PM   #4 (permalink)
SilvertipClassi is on a distinguished road
Mine was the same due to the increase flow that the new slip-ons have. Nuthin goes thru the left pipe. I wasn't happy with that so I bought Tru-dual headpipes and installed them. Now each muffler gets exactly the same amount of exhaust flow goin thru them.
SilvertipClassi is offline   Reply With Quote
Old 09-02-2009, 12:38 PM   #5 (permalink)
Had it checked out, everything is okay...thanks for the imput.
