Fuel MotoRRcycles.comAdvanstarMotorcycleShowsMotorcycle.comAmerican Side Road CycleDan Vance RacingMotorcycle-CommunicationMotorcycle.com Classifieds!MBO EnterprisesBikeBandit
Old 08-25-2009, 12:29 PM   #1 (permalink)
FLHX - 07's Avatar
FLHX - 07 is on a distinguished road
'07 SG dying
About 2 months ago I hit about 5000 rpm and the motor just died. It had spark and the fuel pump running. With a dealer close, they got to in 30 mins. Didn't find anything wrong except it wasn't getting fuel. Removed the fuel line, all looked OK, put everything back together and it started.
I headed for home. About 10 miles away I nailed it and it died again. 15 mins later it started. Did this again just before arriving and the same thing happened.
Bike has PCIII, SE 255 cams, SE HTCC CNC heads, 103 download and 6200 rev limit. I removed the PCIII and threw on some XIEDs I had lying around. I had a lot of rides planned and didn't want any down time. Piled up 1500 miles or so. One day I stopped for about 15 mins, came out and it wouldn't start, no matter how long I waited.
Now at my home dealer, they replaced the ECM and all seemed fine. 1000 miles or so later I headed down an on-ramp and nailed it, died again and would not start. Last saturday and 120 miles from home, I left the bike in a dealer parking lot, doubled up with the ol'ady and went home.
This dealer doubts ECM problem, perhaps a kill switch circuit problem caused by vibration of high rpms...but it going to check everything. Anyone ever seen this before or has any ideas?
Asst Director / Webmaster
Central Michigan H.O.G. #2311
http://cm-chapter.com
Mt. Pleasant, Mi
FLHX - 07 is offline   Reply With Quote
Old 08-25-2009, 02:00 PM   #2 (permalink)
JRPUPINO is on a distinguished road
I would try looking at the fuel pump relay, some friends of mine have had similar problems and that was the fix. I think it was around $48.00 for the relay.Not a bad place to start, also not a bad idea to carry an extra one with ya when your on the road.
JRPUPINO is offline   Reply With Quote
Old 08-28-2009, 05:54 AM   #3 (permalink)
HogBag is on a distinguished road
Try the bike with out the power commander
HogBag is offline   Reply With Quote
Old 08-28-2009, 09:18 AM   #4 (permalink)
My Pig Flies....
MaloloJoe's Avatar
MaloloJoe is on a distinguished road
I think you can switch the lighting relay with fuel system relay to verfiy if the relay is the problem. Don't have my manual with me, but I THINK that's the case. Can anyone confirm they are the same ?
2007 Road King Custom
MaloloJoe is online now   Reply With Quote
Old 09-09-2009, 11:10 AM   #5 (permalink)
FLHX - 07's Avatar
Here's an update:
3rd dealer replaced the fuel filter, fuel pressure regulator and in tank fuel line. Ran fine for 300 miles (stayed out of the throttle). The first time I nailed it, it died again. Waited a few minutes, disconnected the fuel line, hooked it back up and it started. I took off and redlined it in 1st thru 3rd gears....no problem....frustrating as hell!
It's going back to my home dealer who replaced the EMC ($500 for nothing) and I guess we'll see what they do this time.
BTW, it has done this with the Power commander and without, as well as with and without the Xieds.
Mt. Pleasant, Mi
Old 09-09-2009, 01:58 PM   #6 (permalink)
silvrbill is on a distinguished road
Sounds like an electrical connection/sensor/relay problem to me.
silvrbill is offline   Reply With Quote
Old 09-09-2009, 06:28 PM   #7 (permalink)
HARLEYRIDER155 is on a distinguished road
I have a 2008 street glide but I have a buddy that has a 2007 street glide and he had a problem with his fuel line. The bike would stop running and that was it till you removed the fuel line and re installed it ..First time thats all the dealer did to fix it . They said it wasn't on all the way but we tried tugging on it and it didnt fall off or any thing the second time it happened. after the second time they replaced it and its been fine for about a year now....
HARLEYRIDER155 is offline   Reply With Quote
Old 09-10-2009, 08:46 AM   #8 (permalink)
Krayven Sumhead is on a distinguished road
The MoFuCo's "Parts Changers" are giving you your money's worth. Soon the whole engine will be replaced cuz they just can't figure it out. Good Luck.
Krayven Sumhead is offline   Reply With Quote
Old 09-10-2009, 11:20 AM   #9 (permalink)
FLHX - 07's Avatar
After what I've seen and the experimenting I've done, this looks like the most logical culprit. I'm going to keep riding until this fails again a few times. If the fix is to disconnect/connect the fuel line, then that's what it's going to the shop for. Thanks for the info!
Mt. Pleasant, Mi
Old 09-10-2009, 11:55 AM   #10 (permalink)
prophet's Avatar
prophet is on a distinguished road
Does it feel like a fuel problem or does it seem electrical? The reason I say this is that someone on another forum had a problem with the ignition switch on an 08 where it would cut out intermittently. You could look into that as well.
2006 FLHTCUI, 103", Wiseco's .010 over, SE Perf. Heads modified to 86cc's by Jay Riddle Racing, SE Pushrods, Andrews 55N with roller chain mod., S&S Lifters w/HTL, 3.37:1, D&D FatCat 2-1, Kuryakyn Hi-Five Breather, PC 3USB, 25 deg. injectors, Baisley Spring, 114 TQ/110 HP
prophet is offline   Reply With Quote
Old 09-10-2009, 12:15 PM   #11 (permalink)
FLHX - 07's Avatar
I suppose it "feels" more electrical, only because it just dies with no sputtering. On the other hand, at 6000 rpm if the fuel is just cut off, it wouldn't feel any different. Ignition always remained on and the kill switch as well as ignition was always rocked several times with no difference. The only time the problem was ever corrected AFAIK, is when the fuel line was disconnected/connected. Also, according to all 3 techs who saw this in action said, there has ALWAYS been spark when the bike died....just no fuel.
Mt. Pleasant, Mi
Old 09-10-2009, 12:22 PM   #12 (permalink)
F$ck Google ads
ViennaHog's Avatar
There is check valve in the joint with an o-ring that cannot be replaced. Replace the joint and the fuel line as a test. Not a lot of work.
2008 Ultra dark blue pearl
BigBoyz ported street heads
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Magura hydraulic clutch
BaggerBrace stabilizer
Full floater front discs
After Douglas Adams RIP
ViennaHog is offline   Reply With Quote
Old 09-16-2009, 10:55 PM   #13 (permalink)
swordfish is on a distinguished road
ford wiggle test
try idling the bike an start moving and wiggling wires, i'v solved alot of problems that way. could be a bad connection or ground.
swordfish is offline   Reply With Quote
Old 09-17-2009, 10:50 AM   #14 (permalink)
FLHX - 07's Avatar
Good suggestion but, I've already done that. Since then, I've done some intense experimenting wiggling the fuel line at the quick disconnect and several high RPM passes. Each time out of 9 shut downs, an immediate disconnect and connect of the fuel line and the bike fires right up without waiting or hesitation. I've concluded the check valve in the tank or the fuel line tip has worn enough due to vibration or suction in the line, to cause the check valve to close.
Mt. Pleasant, Mi
