I went in on August 19th to pick up my '09 TriGlide and just browsed around the showroom while they were doing the paperwork. I saw the heavy cast-steel-looking wall of the 2 to 1 fitting on the 2010 Tri and got
vewy shushpishus so I cruised the other bikes also. Every one with a 2 to 1 had the same thing. The true duals seemed unchanged, but they might have hidden a cat in there somewhere.
When I went up to sign the papers, I mentioned to the sales manager, "Saw a lotta cats down there..." He gave me a sheepish grin and said, "Yeah..."
I suppose now there will be an active aftermarket in replacement head pipes for 2010 catted bikes with some means of foiling an error code in the ECM, if it is even necessary. There is an active sub-discussion on this subject in the TriGlide Owners thread.
I'm not really blaming HD for doing this if it was necessary to meet EPA emission standards. As I understand it, a richer mix is currently necessary to keep cylinder temps in check and this produces unburned hydrocarbons in the exhaust that must be trapped by the cat.
But I noticed on another bike in the parking lot here that the GoldWing has no problem hiding two longitudinal radiators in the fairing and scooping front-end air across them diagonally on each side. Seems like this would be a possible design improvement on the V-Twins without sacrificing the Harley look and sound and would permit a tuning that would not only comply with EPA but would keep both fuel and heat management efficiencies high.
Wisdom from a j-bike? Hmmmmm
Maybe when I am REALLY old, they will! Or, as an alternative, I'll see if I can marry a watercooled V-Rod engine to a GoldWing fairing on my (by then) ancient TriGlide. I will still not care what people say but, in addition, I'll be too deaf to hear them!
____________________________________________
"It ain't what you don't know that gets you into trouble,
it's what you know for sure that just ain't so..."
Mark Twain
Live well...
Love faithfully...
Laugh often.
Vivid Black '09 TriGlide, V&H Dresser slipons, SE Stage 1 A/C, fairing-mounted oil temp, small bits o' glitz, and rear-hatch H-D rain closet (next project).
