MBO EnterprisesMotorcycle.comLeslie Kay'sAdvanstarMotorcycleShowsSportbikeTrackGearPro PadProCharger.comJekillandHyde.euCustom DynamicsRRcycles.com
Old 08-20-2009, 08:45 PM   #1 (permalink)
Ken w/08 Fatboy's Avatar
Ken w/08 Fatboy is on a distinguished road
Need Advice on Leaks
Help!
My 2008 Fatboy, with 9K miles, recently developed a leak - oil is collecting at the bottom of the primary chaincase cover, right below the derby cover. Neither the engine lower end nor the transmission has been apart, although I had the 103" kit installed 1000 miles. No problems until recently.
Any idea where to start looking? These things can be hard to find, harder to fix - I'm afraid if I bring it into the dealer they'll automatically replace a gasket, but then I'll have the same problem in a month or so ...
Any thoughts are appreciated -
2008 FLSTF
103 cubic inches w/Stage I Air Filter
SE 255 Cam
Rush Pipes - 1.75" Baffles
101.04 ft-lb. torque
Corbin Gunfighter Seat
Chrome Wire Wheels by www.hdwheels.com
Ken w/08 Fatboy is offline   Reply With Quote
Old 08-20-2009, 09:04 PM   #2 (permalink)
Doof Bag
huckinfog's Avatar
huckinfog is on a distinguished road
Did you eliminate the derby cover as the source? if the derby cover has been removed, and the gasket was not replaced, they leak 8 out of 10 times.
Believe in all the good things,that money just can't buy
Then you won't get no bellyache, from eatin' humble pie
I believe in rags to riches, your inheritance won't last
So take your Gray Poupon my friend, and shove it up your as*.-Aerosmith
huckinfog is offline   Reply With Quote
Old 08-20-2009, 09:25 PM   #3 (permalink)
Hmmm ...
The derby cover was replaced some time ago by the dealer's service dept - can't recall if the gasket was replaced along with it - but I think it has been several thousand miles, as I recall. But, the leak is small enough so that perhaps I did not notice it.
But I would think that, if the cover were the culprit, then there would be a slight but still visible streak of oil from the base of the derby cover to the base of the chaincase cover, right?
2008 FLSTF
SE 255 Cam
Old 08-20-2009, 09:43 PM   #4 (permalink)
Wallet Weary
Traakon's Avatar
Traakon is on a distinguished road
oil can be a bit hard to track. Take out a bit of baby powder in your palm and blow it at the base of the derby. If there is an invisible oil trail, it will show.
'00 Custom Deuce, '05 Custom Fatboy, '03 Roag King -current custom project-
-A man and his money soon (and often) parted.-
Traakon is offline   Reply With Quote
Old 08-20-2009, 09:49 PM   #5 (permalink)
Sounds like a useful tip - I'll try it and see if huckinfog's hunch is correct - if not, I'll be back, as an early Fat Boy rider once said -
Thanks, all!
2008 FLSTF
SE 255 Cam
Old 08-20-2009, 11:16 PM   #6 (permalink)
wash it real good, take it for a 15 minute ride put it on a jack get under it to see where its coming from - it is probably on of two hings .... your shifter seal or your mainshaft seal that is leaking. do you have oil in your left side saddlebag or on your chain guard, these are signs tat one or both of these may be leaking.
Old 08-20-2009, 11:31 PM   #7 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
Shift shaft seal leaking is very common. it would show up right where you are finding oil.
Old 08-21-2009, 08:10 PM   #8 (permalink)
Yes - that's a prime suspect, too - had that happen on my '97 Dyna years ago.
2008 FLSTF
SE 255 Cam
