Dan Vance Racing
RRcycles.comLeslie Kay'sJardineProducts.comMotorcycle-CommunicationCustom Dynamics
SportbikeTrackGear
Old 08-02-2009, 08:06 PM   #1 (permalink)
harleys_n_laddertrucks
trucky911's Avatar
trucky911 is on a distinguished road
Cam change to reduce heat
09 Soft Tail Deluxe. Bone stock. Bolt in cam to help reduce heat. Wife's bike. She'll appreciate any recommendations....
Trucky911
trucky911 is offline   Reply With Quote
Old 08-02-2009, 08:26 PM   #2 (permalink)
Dave63's Avatar
Add a fuel management system to give it more fuel , or just richen the EPA MAP and it'll cool down just fine. You'll loose a few degrees with synthetic oil and an oil cooler too, if ya want to go that route.
Changing a cam to loose temps is like Dolly Parton wearing baggy tee-shirts to make herself look more flat chested.
Dave
Old 08-02-2009, 09:23 PM   #3 (permalink)
atrick is on a distinguished road
Changing the cam and adding a fuel mangement system will make the bike run cooler per stroke, It will also make the bike produce more power which will increase heat produced. Bottom line, when sitting at a light it might be cooler for the first 30 seconds after that its just as hot as before. I got a head temperature gauge on mine and watch the temperature all the time and see it first hand! So add those items for a better running machine and you will get a small decrease in heat but these are air cooled engines, the heat is always going to be there!!
07 FXDWG
D & D Slipons
Redshift 575 cam
SE adjustable pushrods
K & N air cleaner
T-Max w/auto tune
Race Tech progressive wound fork springs & emulators
78 SuperGlide
Andrews B Grind w/solids
S & S Super
Dual Pipes
atrick is offline   Reply With Quote
Old 08-02-2009, 09:48 PM   #4 (permalink)
baggersport's Avatar
baggersport is on a distinguished road
...Andrews 37.....S.E. 204....sumthin like that....
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote
Old 08-02-2009, 10:18 PM   #5 (permalink)
mooooving out!
route66paul's Avatar
head quarters
http://www.head-quarters.com/html/twin_cam.html
they have a camset for 07-08 tc and anouther for the 09 with the better gearing. these are designed to drop in stock later model TC engines.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 08-02-2009, 11:18 PM   #6 (permalink)
strokerjlk's Avatar
the overlap is what your looking for.
30 deg or more
without some overlap (intake and exhaust open at the same time) it will never really run any cooler. added fuel helps but isn't enough to do it right!
or as paul said the headquarters should be a good cam desinged for the 08-09's
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
strokerjlk is online now   Reply With Quote
Old 08-03-2009, 10:05 PM   #7 (permalink)
trucky911's Avatar
Thanks for the replys guys. Andrews, S/E. or HQ. It will be one of them. Hmmm, now witch tuner?...
Trucky911
Old 08-03-2009, 10:58 PM   #8 (permalink)
strokerjlk's Avatar
Trucky911
TTS Mastertune ,SEST, OR SERT (if ya can find one)
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 08-04-2009, 03:14 AM   #9 (permalink)
Ozroder's Avatar
Ozroder is on a distinguished road
Andrews 54
Ozroder is offline   Reply With Quote
Old 08-04-2009, 03:36 PM   #10 (permalink)
96 inchers love the 26 it will cool it down and add the tts tuner done deal. The 37 54 work as well however with the rather low compression they tend to move the tq up further than so like it. The 26 has done great with well over 2 dozen installs that we have done. Just completed one with true dual pipes. makes very usable tq even with the poor pipes the customer had installed prior to use adding the cam.
File Type: jpg 08 flhri 26 cam V&H t duals K&N filet kit e-mail.jpg (129.9 KB, 39 views)
GMR PERFORMANCE
928-445-3473
TTS TUNING CENTER AND SALES
WWW.GMRPERFORMANCE.COM
Old 08-04-2009, 06:55 PM   #11 (permalink)
yeah, i use the venerable 26 to overcome the shortcomings of true duals also. its a shame though, it is a great cam to be killed by pipes. ever thrown a set of 26's in a 96 with stock exhaust? makes ya slap yo momma!
Old 08-04-2009, 06:56 PM   #12 (permalink)
RG09 is on a distinguished road
Any thoughts on the S&S 510 cam? A tech at my stealer is pushing it pretty hard...
RG09 is offline   Reply With Quote
Old 08-04-2009, 07:13 PM   #13 (permalink)
thought it was slap your grandma??? LOL
GMR PERFORMANCE
928-445-3473
Old 08-04-2009, 08:31 PM   #14 (permalink)
strokerjlk's Avatar
Na.....put true duals on it ......the really loud ones.....then ya can slap your grandma!
or is it blip your grandma....I get so confused!
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 08-04-2009, 08:35 PM   #15 (permalink)
trucky911's Avatar
Clay and HD your such kidders. I'm having a bad day and your cuttin up brought a smile to my face. Thanks. A few hours ago i had decided to use the S/E 204. Now its back to the 26...Decisions, decisions, decisions........
Trucky911
