Dan Vance RacingJekillandHyde.euMotorcycle.com Classifieds!BikeBanditDiamond Bar ChoppersFuel MotoLeslie Kay'sPro Pad
MBO Enterprises
Old 07-31-2009, 05:47 AM   #1 (permalink)
ianz83's Avatar
ianz83 is on a distinguished road
Hard To start when hot??
When I stop my bike for, lets say 2 minutes or more when it is at operating temp it is really hard to re-start (can take up to 5 secs or more). after it has cooled a bit or if i re-start straight away it's fine.
Now I know there is probably something I can do with the tune to correct this but I am just unsure what??
Has anyone had any similar problems?
TIA
2008 FXDB
96" ci 10:1
Ported Heads
SE stg1 A/C
S&S Slash Cut's
SE 211 Cams
SEST & Daytona Twin Scan2 w/WEGOIIID
ianz83 is offline   Reply With Quote
Old 07-31-2009, 05:50 AM   #2 (permalink)
ianz83's Avatar
I should add that when she does fire up it's really doey, doesn't want to idle. like it's running rich
2008 FXDB
96" ci 10:1
Ported Heads
SE stg1 A/C
S&S Slash Cut's
SE 211 Cams
Old 07-31-2009, 11:54 AM   #3 (permalink)
HD did offer on some models a re flash . They reduced the timing on cranking. This and much more can be done with the TTS. HD is trying to run 24-25 of initial timing , ???? they need 12-15 and will start much easier and in many cases the starter clunk that some claim is the comp issue is gone.
GMR PERFORMANCE
928-445-3473
TTS TUNING CENTER AND SALES
WWW.GMRPERFORMANCE.COM
Old 07-31-2009, 03:50 PM   #4 (permalink)
ianz83's Avatar
will have to check out the timing. I'm pretty sure ATM it's set at 14 degrees
2008 FXDB
96" ci 10:1
Ported Heads
SE stg1 A/C
S&S Slash Cut's
SE 211 Cams
Old 07-31-2009, 11:50 PM   #5 (permalink)
henry77 is on a distinguished road
Its the fuel pump!!! I had the same problem to the tee. I told HD I thought it was the fuel pump last year, so they checked everything but that!! They FINALLY got it to malfunction.....replaced it, never had any problems since! Make them replace it!!!
henry77 is offline   Reply With Quote
