Got the Jag cooler and adapter on mine and they are great units, but one problem I ran into is when you go to remove the filter again the whole adapter wants to spin with the filter then you have to redo the whole thing. When you go to redo the filter you need to stick something between the adapter and frame to keep it from spinning and you got to watch what filters you run, some don't seal as well as others and you have to tighen the crap out of them to keep them from seaping.
07 FXDWG
D & D Slipons
Redshift 575 cam
SE adjustable pushrods
K & N air cleaner
T-Max w/auto tune
Race Tech progressive wound fork springs & emulators
78 SuperGlide
Andrews B Grind w/solids
S & S Super
Dual Pipes
