From another post:
"Syn 3 in the primary will work OK, but there are better choices available. I've used many 20W-50 synthetic motor oils that are JASO MA certified and have never had any clutch slippage, but I did start to experience a "grabbiness" feeling in the clutch action. I switched to Bel-Ray 80W Gear Saver Transmission Oil which is also their "Primary Chaincase Lube" and will never go back to using motor oil in my primary again. The Bel Ray product is great and my clutch action is smooth as silk!"
PS, I've also used 20W-50 motor oil, 75W-90 gear oil, RL Shockproof Heavy in the transmission and my favorite that I'm now using is Amsoil Severe Gear 75W-110.
You should capitalize on the Harley advantage which allows you to use specialty lubricants for specific applications rather than 1 general lubricant for 3 different purposes...
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
SE 257, HTCC Heads & Intake
Hooker Troublemaker Pipes
