Originally Posted by vindex1963
I searched.....really.
How much can the O2 sensors compensate for when doing slip-ons and air cleaners? Isn't that the idea of the loop system? Why is there a stage one download when the system is designed to keep the air fuel ratio in a certain spec? I'm looking at getting a new FL with a 96" and am trying to learn all I can before I buy. I'll probably get a Geezer-Glide sooner than later.
Is there certain years of 96" to avoid?
Have not seen you post in a while good to see you. The 02 sensor does not have enough range to adjust for the add on you installed. Now that is until you tune the bike. Once tuned and you get the afr to say 14.3 with a 02 bias of 781 ( example) it will then be able to toggle some and keep your afr with the specs. Feel free to give me a call or even stop up at the shop and I will show you the TTS sheeets from a before and after set up and you will see how far they need to be adjusted with just the basic exhuast and air cleaner mods. Have a 09 on the dyno today with a/c V&H t-duals and monster ovals.
In the end a tuner is the only way to get the bike correctly tuned, money well spent. Take care
