Leslie Kay'sSportbikeTrackGearDan Vance RacingPowerstar Sparkplugs
Stainless Ride Specialty AccessoriesDiamond Bar ChoppersBikeBandit
Custom Dynamics
Old 10-24-2008, 09:57 PM   #1 (permalink)
gpp
gpp
reduce compression
i have a set of se heads for my 103 build that yeild about 10.80 compression according to the harley chart.how can i get it down to about 10.01?
gpp is offline   Reply With Quote
Old 10-24-2008, 10:53 PM   #2 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
I'm sure there is a way to do it with the heads, but it's probably easier and cheaper to change the pistons. Unless what you have already yeilds the lowest.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
Old 10-24-2008, 11:05 PM   #3 (permalink)
fastroadking106 is on a distinguished road
heads gaskets
It takes a good engine guy but there are many different thickness head gaskets on the market that would be the cheapest and easiest
fastroadking106 is offline   Reply With Quote
Old 10-25-2008, 07:27 AM   #4 (permalink)
Premium octane member
TXCHOP's Avatar
That's right...but......Going with a thicker headgasket will open up the squench area a bit much. Not too good for pinging and tuning issues that may occur. I would rather send the heads out to a good machine shop to be opened up a bit or switch out to a dished or custom piston.
TTS tuned by Jd's Cycleworks
Black Boarzilla
Wood's TW9FG cams
Old 10-25-2008, 08:43 AM   #5 (permalink)
True that is how i do my builds but just giving another option I beleive at just 10:1 there should not be any tuning problems
Old 10-25-2008, 07:42 PM   #6 (permalink)
gpp
gpp
so if i double the gasket thickness about what would it take to do this?
Old 10-25-2008, 09:25 PM   #7 (permalink)
first off, forget about the harley chart. CC the heads and tell which pistons you have. the CORRECT math can then be done.
claydbal is online now   Reply With Quote
