Good oil coolers - Page 3 : V-Twin Forum: Harley Davidson Forums
Old 02-21-2012, 06:50 PM   #31 (permalink)
Greg MacD's Avatar
Greg MacD wants to know Dino or Syn?
Jagg oil cooler, I use one down here in Florida, works well.
2006 FLHTPI
2003 Aprilia RST 1000
2004 Suzuki DRZ 400 (Motarded)
2003 Ford SD 7.3L Diesel
Greg MacD is offline   Reply With Quote Quick reply to this message
Old 02-27-2012, 12:01 PM   #32 (permalink)
Holdtheline's Avatar
Holdtheline wants to know Dino or Syn?
Is there a trade off in oil pressure loss, using the JAGG. It would seem the restriction inline of the cooling grid may affect oil pressure?
Holdtheline is offline   Reply With Quote Quick reply to this message
Old 04-15-2012, 06:39 PM   #33 (permalink)
bgdv1's Avatar
bgdv1 wants to know Dino or Syn?
went with the HD cooler. went for a 30 mile ride today, temps were upper 70's. wife wanted to take her bike out for a putt so i followed along.( new rider)when we got back i hit the button on the temp dip stick and 245* was hoping to see around 230* but i can live with that. does the Jagg adaptor make that much of a difference in temp drop ??
2011 Street Glide
bgdv1 is offline   Reply With Quote Quick reply to this message
Old 04-15-2012, 07:10 PM   #34 (permalink)
Milan's Avatar
Milan wants to know Dino or Syn?
Now that you got a oil cooler, get this fan kit. You wont be disappointed.
http://bigskyfan.tripod.com/id10.html
Milan is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 05:20 AM   #35 (permalink)
Captain Oblivious
Fred1369's Avatar
Fred1369 is still riding a stock bike Fred1369 is still riding a stock bike
or you could get a water/oil cooled bike.
Fred1369 is offline   Reply With Quote Quick reply to this message
Old 10-19-2012, 10:51 PM   #36 (permalink)
.A.R.M. RIDER
tleahy wants to know Dino or Syn?
I use an OIL BUD cooler on my 09 ROADKING, it mounts flat under the motor totally out of sight and is t-stat controlled, temps run about 220.
tleahy is offline   Reply With Quote Quick reply to this message
Old 10-20-2012, 06:31 PM   #37 (permalink)
smitty901's Avatar
smitty901 is reading this now saying WTF is this?
The stock Hd cooler is as good as most of the others.
If you want to make the oil cooler more effective this simple low cost add on works.
Infantry leads the way
smitty901 is offline   Reply With Quote Quick reply to this message
Old 11-14-2012, 06:49 PM   #38 (permalink)
cycleman wants to know Dino or Syn?
I run the HD oil cooler on my 08 Softail. It does drop the oil temps by about 20 F.
When you install the adapter you have to make sure you get it torqued right. I like it because it has the thermostat.
cycleman is offline   Reply With Quote Quick reply to this message
Old 11-15-2012, 12:35 AM   #39 (permalink)
Ricks 03FXST's Avatar
Ricks 03FXST wants to know Dino or Syn?
Has anyone used one of these?
Ricks 03FXST is offline   Reply With Quote Quick reply to this message
Old 11-15-2012, 04:47 PM   #40 (permalink)
smitty901's Avatar
Yes and it works
Old 10-29-2013, 10:54 PM   #41 (permalink)
John Goldsmith wants to know Dino or Syn?
I'm going to try the UltraCool Reefer unit on my 07 Ultra Classis. It has 17 rows of tubes and two fans that come on at 220 degrees and go back off at 180 degrees. It appears a little bulky in size, but I will live with that if it works. My ride is a 103 big bore with SE 255 cams, SE A/C and SE 4" Street Performer slip-ons. I have also added a SEPST and set the AFR's to 12.8 --13.2. It is running a lot cooler now and still gets 44MPG.
John Goldsmith is offline   Reply With Quote Quick reply to this message
Old 10-30-2013, 12:49 PM   #42 (permalink)
Olivepearl wants to know Dino or Syn?
A good ole Jagg cooler fits the bill for any bike and if you chucked those 255's for something better it would run much cooler on top of that.
Olivepearl is offline   Reply With Quote Quick reply to this message
