96 Engine Specs : V-Twin Forum: Harley Davidson Forums
Old 01-07-2008, 11:47 AM   #1 (permalink)
wpnssgt's Avatar
wpnssgt wants to know Dino or Syn?
96 Engine Specs
I've searched the threads and google and can't seem to find some specific info on a stock 96" engine. I'm looking for the Min RPM, Max RPM, Shift Up RPM, Shift Down RPM, & Max Power RPM. Anyone know this info? I probably missed it or mis-typed in my search. Thanks
2007 Kawasaki ZZR600 (1st Bike, traded in for FXDB)
2008 Street Bob
1981 CB900C
1971 Honda CB175 Racer Project
wpnssgt is offline   Reply With Quote Quick reply to this message
Old 01-07-2008, 01:31 PM   #2 (permalink)
adlerx's Avatar
adlerx wants to know Dino or Syn?
I don't understand the question. I ride higher than most in the rpm range so my shift points wouldn't be anywhere close to minimums. Most guys lug these motors around shifting at or below 3.5k. BTW, 3.3k is where the fun starts
adlerx is offline   Reply With Quote Quick reply to this message
Old 01-07-2008, 01:44 PM   #3 (permalink)
wpnssgt's Avatar
This is info I need for a gearing worksheet in excel. Most engines have a "standard" shift RPM, even though most if not all don't use it.
2008 Street Bob
1981 CB900C
Old 01-07-2008, 04:02 PM   #4 (permalink)
Rockbiter's Avatar
Rockbiter wants to know Dino or Syn?
idle rpm: 1050 +/- 50
rpm max: 5500
shift point varies to rider (I shift high for VROOM, shift low for calm riding)
downshift point same, but avoid heavy downshift, you could throw your crank out
Most of this should be in the Owners Manual, or the Maintenance Book
I have a max-rpm comparison exell sheet avail if you'd like to see it (theoretical max speeds calculated from engine gearing, rpm, and rear tire sizes)
My FXD theoreticly maxes at 158...does it actually have the power to do that? most likely not ...but its fun trying!
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote Quick reply to this message
Old 01-07-2008, 06:22 PM   #5 (permalink)
wpnssgt's Avatar
rpm max: 5500
That's the info I needed, Thanks Scott!
Shoot that excel sheet to me, home email will be fine. If you forgot it check your PMs
2008 Street Bob
1981 CB900C
Old 01-07-2008, 08:05 PM   #6 (permalink)
adlerx's Avatar
rpm max: 5500
GREAT Expalnation! Good job. And it it is fun trying!
Old 01-07-2008, 09:17 PM   #7 (permalink)
Qhorin wants to know Dino or Syn?
I have it all on exel also .I have it fo r the 06 and under 5 speed and the 07 6 speed and the 6 speed with the 30 tooth sprocket replacing the stock 34toother. I tryed for a couple hrs to post them all but I couldnt get it to work. I keep the 30 tooth spreadsheet in my wallet(dont need a tack)for reference. The following is a 30 tooth example: I like to shift into 2nd at around 30mph or 4000rpms then into third at alittle over 40 which is around also around 4000 in second gear. When i want to be alittle more aggressive (very often) Ill shift at 35mph into second (almost 5000rpms) then into third at around 50-55 which is 4800 to 5300rpms. Its all write on the sheet .Its a shame I cant figure out how to post it for yas.
07 fatboy,103bb, hq 575 cams,bigboyz heads,stockheadpipes/rush mufflers,30tooth sprocket
Qhorin is offline   Reply With Quote Quick reply to this message
Old 01-07-2008, 10:49 PM   #8 (permalink)
Bubba Neil wants to know Dino or Syn?
rpm max: 5500
If I shift when the 07 owners manual tells me to I would be lugging the bike.
Pretty much a known fact that it is incorrect.
The 96" likes a little more rpm due to the taller gearing, easy to lug if coming off a 88" IMHO.
Bubba Neil is offline   Reply With Quote Quick reply to this message
Old 01-07-2008, 11:23 PM   #9 (permalink)
Rockbiter's Avatar
If I understand what wpnssgt is trying to do, is recreate one of those speed/rpm/gear charts like they use in those sport/tuner mags, showing the "performance envelope" of the vehicle. I've wanted to do that for years, but couldn't wrap my brain around Excell well enough to make it create the chart properly (I think you need to create an algorythm for each gear/rpm to show the speed, then overlay all 5 (6) speeds to see the final graph...)
I hope it works wpnssgt, I wanna convert it to my bike to see how mine fares
'04 TC103 FXD
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE Clutch spring
Old 01-08-2008, 10:00 PM   #10 (permalink)
d1hojo's Avatar
d1hojo wants to know where he is and how he got here
rpm max: 5500
Wide open on my 07 softail would only hit 120 and it took way to long to get there.
2007 FXDWG-Gone but never forgotten.
d1hojo is offline   Reply With Quote Quick reply to this message
Old 01-08-2008, 10:12 PM   #11 (permalink)
Colorado crusin'
NewHawk's Avatar
NewHawk wants to know Dino or Syn?
Did you enjoy it or were you looking for a quick finish?
NewHawk is offline   Reply With Quote Quick reply to this message
Old 01-09-2008, 09:35 AM   #12 (permalink)
Rockbiter's Avatar
There is a big diffrence between theoretical max speed and actual max speed. My 04 Superglide (when stock) was like yours, could only manage 115-120.
Now add a high rpm ignition module, big bore engine, and a decent size pair of cajones, and you can easily achieve ...ahem...more interesting max speed numbers.
When you calculate the theoretical max speed, it ONLY takes into account engine RPM multiplied by primary gearing, transmission gearing, final drive gearing, and rear wheel circumfrence. It does not figure in engine power, drag, that extra piece of pie you had for dinner, or any other factor.
With a stock 04 FXD TC88, you might get numbers like this (please forgive the poor formating, excell does not seem to transfer well in this format, also, numbers used are best approximations from published tech data):
Bike Datails 04 FXD Stock
Max Engine RPM 5200
Primary Drive Ratio 1.440
Final Drive Ratio 2.188
Rear Wheel Radius in Inches 13
Max Clutch RPM 3611.111
Rear wheel cir in inches 81.68
Inches in a mile 63,360
Gear Number 1 2 3 4 5
Ratio 3.206 2.208 1.572 1.226 1.000
Calculate Numbers
Max Wheel RPM 514.969 747.512 1,050.109 1,346.760 1,651.171
Max inches per minute 42063.40703 61057.83428 85774.36119 110005.2851 134869.9717
Mechanical Speed MPH per gear 39.83 57.82 81.23 104.17 127.72
With my bike, a mildly modified 04 FXD TC103 you might get numbers like this:
Bike Datails FXD
Max Engine RPM 6200
Max Clutch RPM 4305.556
Calculate Numbers
Max Wheel RPM 614.002 891.264 1,252.053 1,605.753 1,968.704
Max inches per minute 50152.52376 72799.72549 102269.4306 131160.1476 160806.5048
Mechanical Speed MPH per gear 47.49 68.94 96.85 124.20 152.28
This is not really usefull in real life, but it is interesting from a thoretical standopoint.
'04 TC103 FXD
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE Clutch spring
Old 01-09-2008, 06:31 PM   #13 (permalink)
d1hojo's Avatar
It was fun, it just kinda pissed me off that it took so long between 110 to 120.
Old 03-08-2008, 09:54 PM   #14 (permalink)
grandpa Tom's Avatar
grandpa Tom wants to know Dino or Syn?
I looked for a good RPM vs MPH chart also,
Go to Nightrider.com or search Nightrider... In the lower right corner in home page you can click on rpm vs mph, enter your gear ratios and print out in a bunch of ways of your picking... it is a very usefull chart...
Retired
07 FLSTC, 47k miles
SERT, SE/K&N, Rush
Andrews 26h cams
grandpa Tom is offline   Reply With Quote Quick reply to this message
