Best spark plug? : V-Twin Forum: Harley Davidson Forums
Old 12-21-2007, 08:21 PM   #1 (permalink)
This space is blank
DCRANER's Avatar
DCRANER wants to know Dino or Syn?
Best spark plug?
Have an 07 FLHRS with K&N, Slip-Ons, Stage1 Download, and V&H FuelPak.
So:
Stock HD plug 6R12
NGK DCPR7E
Autolite 4164
Maybe i heat range colder?
2012 Heritage Softail Classic, profile laced wheels, security, ABS, two tone color - Ember Red Sunglo / Merlot.
DCRANER is offline   Reply With Quote Quick reply to this message
Old 12-21-2007, 08:34 PM   #2 (permalink)
Bubba Neil wants to know Dino or Syn?
I believe the stock plugs are the ion sensing, that is how the delphi system manages the spark knock......
So if you go to another plug you lose that, not sure how the ecm reacts after that.
Remember a post about using colder heat range plugs in a 07.
Not saying it won't work.... it may not cause any issue.
Bubba Neil is offline   Reply With Quote Quick reply to this message
Old 12-21-2007, 09:30 PM   #3 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
Stock H-D plugs work fine.
road_king is offline   Reply With Quote Quick reply to this message
Old 12-22-2007, 12:47 AM   #4 (permalink)
The Anti-RUB
petrock's Avatar
Another vote for stock.
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 12-22-2007, 01:33 AM   #5 (permalink)
berserker's Avatar
berserker is still riding a stock bike berserker is still riding a stock bike berserker is still riding a stock bike
Don't start playing with heat ranges. If your asking this question, you will get into trouble.
You have been on this site since 04, this is typically 1st 50 post question.
berserker is offline   Reply With Quote Quick reply to this message
Old 04-03-2011, 08:13 PM   #6 (permalink)
kf4wsn wants to know Dino or Syn?
I prefer the Denso or NGK Iridium in my 05 Ultra I can see a big difference in the mid range and they last way longer. I had a pal with a bad coil that would not fire the stock plug i put in an old set of my Iridium plugs and it fired and he rode home they take less voltage to fire
kf4wsn is offline   Reply With Quote Quick reply to this message
Old 04-03-2011, 08:36 PM   #7 (permalink)
HATER OF THE GRAVEL!!!!!!
Jeffytune's Avatar
Jeffytune is reading this now saying WTF is this?
With any O2 controlled system, I have learned over many years it is best to use what the factory engineers designed and installed.
I can get NGK and Autolite plugs for 1/3 the cost of factory Harley plugs, and I run the Factory Harley plugs in my bike.
It simply runs better with them then it has with any other plug I have tried.
I'm Just Sayin'...
2010 FLHTCUI
96 CID w/ the quiet 6 speed
K&N RK-3930 air filter
Harley quiet high flow 110 mufflers
Vance and Hines Fuelpak
Professional Rockat Surgen
Disclaimer.
Jeffytune is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 09:47 PM   #8 (permalink)
harley-gearhead wants to know Dino or Syn?
Another vote for the factory 6R12. I've tried alot of different plugs, and I've always went back to the HD 6R12.
harley-gearhead is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 07:39 AM   #9 (permalink)
troop wants to know Dino or Syn?
I see this is a revival of an old post and I'm pondering the same situation. I just had a new build done and am going to put in new plugs when I get my final tune done in about 500 miles. Stock (original) plugs have about 7k miles on them so what the hell. I was pondering stock 6R12, 6R12 Platinums or one range cooler with NGK DCPR8E. I understand that the stock plug has the ion sensor for the EFI anti-knock. Weird how they do but the upgraded 6R12 golds/platinums don't? Bottom line for me is I believe I'll have it tuned with the stock 6R12's. For the cost of a quart of oil, I'll get two spark plugs and the anti-knock ability. Cheap enough to replace every other riding season (or every season if desired)...
103" flat tops with .030 hg
Tom Wirth Street Port Heads
Andrews 54H Cams/1.725 rocker arms
K&N Aircharger/SEPST
V&H Pro Pipe
JVC/BT4180 Amp/Focal/Kicker/HT Lids
troop is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 07:46 AM   #10 (permalink)
sporty952 wants to know Dino or Syn?
You mean until they're so corroded that the threads come
out when you change the plug at 30K miles?
-W
sporty952 is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 08:36 AM   #11 (permalink)
Basic Hog Rider
xxxxxkwizard wants to know Dino or Syn?
I use Champion RA8HC. They go on sale at Autozone for 99 cents and I usually buy a dozen. I put a fresh set in every 5k miles, a little anti-sieze on the threads, di-electric grease on the boots, never had a problem.
xxxxxkwizard is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 10:41 AM   #12 (permalink)
Yeah, I hear ya. Talking to the tuner/tech yesterday, he said they rarely, if ever, see any engine codes popping up spark plug related. He said FI and modern ignition technology make fouled plugs a thing of the past. He did say that most customers opt for the 2x expensive platinums and they don't have the anti knock ion sensor built in. Kinda sounds funny to debate $2.00 (RA8HC) > $3.75 6R12 after pouring in $1600 for a build/tune
V&H Pro Pipe
Old 04-22-2011, 01:58 PM   #13 (permalink)
nvsteve wants to know Dino or Syn?
Ion sensing built in?? I don't think so.
The RA8HC is the same plug as the 6R12.
nvsteve is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 02:27 PM   #14 (permalink)
Not according to the bottom of this? Same heat range specs maybe, but something a bit different? I dunno.....
http://harleyhelp.com/sparkplg.html
http://www.hdtalking.com/diagnostics...explained.html
"To clear up about the Harley Delphi EFI antiknock control theory.
This system uses ion-sensing technology to detect detonation or engine misfire in either the front or rear cylinder by monitoring the electrical energy at the spark plug after every timed spark. If an abnormal level of energy is detected across 2 or 3 spark firings the ECM responds by retarding spark timing in that cylinder as needed to eliminate it."
Non-stock plugs or wires can cause inaccurate data to get to the ECU and a false misfire signal / error code."
V&H Pro Pipe
Old 04-22-2011, 02:30 PM   #15 (permalink)
speedfoos's Avatar
speedfoos wants to know Dino or Syn?
I'll third this.
| PHOTOS |
speedfoos is offline   Reply With Quote Quick reply to this message
