Bike Bandit
Old 07-11-2007, 09:25 AM   #1 (permalink)
jschmuck is on a distinguished road
Andrews 21 or 26?
On a heavily loaded 07 Electra Glide that is stock which is the better cam? Which one has a smoother idle? Thanks for the help.
2007 Electra Glide Classic
Tmax Autotune
SE Stage 1 Air Kit
Modded Stock Exhausts
Andrews 26 Cams
jschmuck is offline   Reply With Quote
Old 07-11-2007, 09:31 AM   #2 (permalink)
Andrews 21 or 26?
Which is the better cam to use on a 2007 Electra Glide pulling a trailer and with a passenger? Which has a better idle? I have not been able to find posts on anyone that has used the 21 cam. Thanks for your help.
Tmax Autotune
SE Stage 1 Air Kit
Andrews 26 Cams
Old 07-11-2007, 10:06 AM   #3 (permalink)
killer sperm
Milehog's Avatar
Milehog is on a distinguished road
How extensive are your planned modifications? If it's Stage1 stuff and a cam I'd suggest the 21, it works well with stock compression.
xxxxxxxxxxxxxxxxxxxxx
Milehog is online now   Reply With Quote
Old 07-11-2007, 10:20 AM   #4 (permalink)
Yes it is a Stage1 with a Tmat. My main concern is nice driveablity as oppossed to best 1/4 mile time.
Tmax Autotune
SE Stage 1 Air Kit
Andrews 26 Cams
Old 07-11-2007, 11:26 AM   #5 (permalink)
deuce04's Avatar
deuce04 is on a distinguished road
Actually either cam should give you what your looking for
deuce04 is offline   Reply With Quote
Old 07-11-2007, 11:28 AM   #6 (permalink)
Pestilence
Flyer is on a distinguished road
21 signs on and off a little sooner on the rpms than 26. Both very torquey.
Very gentle on the valvetrain.
Flyer is offline   Reply With Quote
Old 07-11-2007, 12:41 PM   #7 (permalink)
Average Dude
YankeeBob's Avatar
Threads merged.
Please don't double post.
Deut. 23:12-13
Old 07-11-2007, 06:01 PM   #8 (permalink)
Paniolo is on a distinguished road
I'd go with the 26.
Paniolo is offline   Reply With Quote
Old 07-11-2007, 11:09 PM   #9 (permalink)
ToBeFrank's Avatar
ToBeFrank is on a distinguished road
I have an 88 but I just put the 26 in my bike. Pulls very good just off idle up to 5000. I'm very happy with it.
ToBeFrank is offline   Reply With Quote
Old 07-12-2007, 12:38 AM   #10 (permalink)
Originally Posted by YankeeBob
Threads merged.
Sorry - Won't do it again.
Tmax Autotune
SE Stage 1 Air Kit
Andrews 26 Cams
Old 07-12-2007, 04:52 PM   #11 (permalink)
05 classic is on a distinguished road
crane 6000 very happy
2007 flstc slip ons at 500 miles. crane 6000 cams at 2000 miles now at 4200 miles no tuning runs fantastic plugs look good. Since cam change motor runs cooler, no pinging, and hot restarts are not a problem. One problem is back tire its gone, do a lot of riding on back roads and i belive (power is strong and now) eating it up. rear tire on my 05 would last 9000 miles. But anyway i love the power band i hardly ever give it full throttle because it just goes so good at mid throttle openings.
05 classic is offline   Reply With Quote
Old 07-12-2007, 11:02 PM   #12 (permalink)
DILLIGAF
berserker's Avatar
96 is not a 98. tranny is geared differant and bigger stroked engine behavfes differant. No answer. But I am waiting for some 96" designed cams.
Old 08-09-2007, 01:12 PM   #13 (permalink)
iclick's Avatar
iclick is on a distinguished road
Me too. I've seen two dyno charts on 26's installed in 96" engines, and the results are underwhelming, with barely any improvement either in TQ or HP. These cams seem to work well with earlier TC's, but not the 96.
iclick is offline   Reply With Quote
Old 08-16-2007, 04:58 PM   #14 (permalink)
foddlefadel is on a distinguished road
Could you share with me any other changes you mad to your bike? I am very interested in this cam for my '07 RG. Did you do a dyno tune or just install the cam?
thanks
Dave
foddlefadel is offline   Reply With Quote
Old 08-16-2007, 05:09 PM   #15 (permalink)
I saw the same dyno run posted where a tw26 made little improvement on a 96" motor. I keep asking for the specs on the '07 cams but never receive an answer. If the 96" cams or so bad why do they post the torque numbers they do, I'm sure that the stock heads reduce the HP number just as they would on a 95" with no head work.
The only people I hear rave about bolt in cams on the 96" motor are the ones who use the crane 1-6000. Some of the sponsers are recommending the TW37 as a bolt in. I don't see how you would have much low end pull with it in a stock 9.2 engine.
Dave
