Progressive Insurance
Rosa's CycleKomodoGear.comAdvanstarMotorcycleShowsOriginalBikeSpirits.comMetalArtsTech N' Cycle GearExtreme Custom EngravingWheeldock.comArnottAirRideDaytona Twin-TecPro Pad
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Twin-Cam 88" Engine Technical Discussions
Motorcycle.com
Old 01-31-2007, 11:10 PM   #1 (permalink)
Insert clever statement
OblivionAxe is on a distinguished road
After Build Question ...
Two quick questions ...
1) Had a 95" build done last year and the Indy told me to bring her in after 500 miles. I moved before that number was reached and need advice on what he might need to have performed at that point. Already did the oil change and new plugs, just want to know what I'm missing. I'm great with a wrench and solid advice, so it'll be great to hear what you think.
2) Also, When you re-torque anything that has loctite should you remove the bolt, clean it, then re-apply the appropriate strength loctite? Or do you just torque the fastener to spec without removing it?
Thanks !!
2004 Road King FLHR
95" Upgrade:
SE Flat Top Pistons
SE Gasket kit
SE 203 Cam
Stock CV Carb
Wimmer Mini-Max Intake
Vance Big Shot Duals
OblivionAxe is offline   Reply With Quote
Old 01-31-2007, 11:21 PM   #2 (permalink)
FYJIGM
DNLEVESQUE is on a distinguished road
Sounds like you might have a good Indy who just wants to make sure your bike is good to go after the break in period. You might have saved yourself a few bucks change the fluids yourself bit I think it's worth at least calling him to see what he wants to check. As for the locktite, I always clean my bolts and then reapply new before torqueing back. That's just good practice and leaves you with no doubts if you did it right or not.
05 Chopper Blue/Brilliant Silver Springer Classic
V&H Big Shot Staggered exhaust
Ness Big Filter
98" RevPerf BB kit
37g cam's
DTT ignition
Heads CNC'd by GMR
Mik 42 carb
LMR-2 oil spring
SE Diaphragm Spring
VPC 92T
SE intake manifold
DNLEVESQUE is offline   Reply With Quote
Old 02-01-2007, 03:14 PM   #3 (permalink)
Ironbutt
miles to go is on a distinguished road
As long as the bike is running good, really nothing that needs to be done except oil/filter change. No need to even change the plugs.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
2000 XL1200S
miles to go is offline   Reply With Quote
Old 02-01-2007, 03:19 PM   #4 (permalink)
bigbluff is on a distinguished road
I'm guessing, but he may have wanted to run a compression test.
Some people are like Slinky toys...not good for much of anything, but it gives great pleasure to push them down the stairs.
bigbluff is offline   Reply With Quote
Old 02-02-2007, 09:07 AM   #5 (permalink)
WE check comp level, leak down, as well go back over anything that we have taken off to ensure all is tight, as well we will check for intake leaks, and any other thing that could be leaking from the build. One thing that we see on a regular basis on the bikes with foot boards is a loose right front mount. But then agian in these tight twisty roads they will drag the board and force it loose. We use red loctite and, as well the cleaner, and primer and have found that to be the solution to keeping them tight. We like to see them back in a few hundred miles for a wuick once over if they are local, if not I go over what to watch for. On build we will put 30 miles on the build and then come back and go over the normal stuff like ex studs, ex brackets that tend to move around more than other items. Follow the service manual for the spes on those items give them a tq check and I am sure you will be ok.
GMR PERFORMANCE
928-445-3473
TTS TUNING CENTER AND SALES
WWW.GMRPERFORMANCE.COM
Old 02-02-2007, 02:14 PM   #6 (permalink)
Appreciate the info guys !!!
And a special thanks to HDWRENCH ... I was hoping to hear from a respected builder and you came through.
Thanks again everyone.
- KB
2004 Road King FLHR
95" Upgrade:
SE Flat Top Pistons
SE Gasket kit
SE 203 Cam
Stock CV Carb
