» Buyers Guides |
07-26-2005, 04:46 PM
#46 (permalink)
I was 1st going with the B spring on my build before I seen the stock oil pump. I decided to go fueling & on fourm members advice put the spring in to. I got so much cold oil PSI it pegged my 60 psi gauge. I never had a oil PSI problem before and now when its hot I still dont have a oil psi problem. When is too much oil psi a bad thing?
07-28-2005, 12:53 AM
#47 (permalink)
...When your bike starts pissing oil outta all the gaskets, probably...or when your oil pump goes **** up because of too much cold oil pressure.....
Good luck.
09-18-2005, 02:26 PM
#48 (permalink)
I have been reading the posts on this spring. Went out and bought one and took it to my mechanic. He told me that it wont work on my bike because i have a gear driven oil pump???I dont think he ever read the instructions because i dont think it has anything to do with the oil pump. Am i way off on this or is he correct in saying it wont work on myh bike.
03 electriglide classic with fuel inj. stock
09-18-2005, 02:31 PM
#49 (permalink)
It'll work and it's an easy install.
09-18-2005, 02:36 PM
#50 (permalink)
You need a mechanic.
207-242-8374 Cell Phone
207-621-8089 Port Shop/Dyno Shop
09-18-2005, 03:48 PM
#51 (permalink)
European Tour
Ordered mine last week..should be here (Germany) anyday...Can't wait..Nice weather's going fast...
2003 FXDWG
My Dyna
103" SE
6 Speed SE
V&H BigShots
Crane HI-4TC
09-18-2005, 03:50 PM
#52 (permalink)
Good luck.
Have to admit I wondered this. Is it a matter or the company doing the best thing after lots of research or the company not fixing a problem?
2001 FLHR, RP 98", GMR heads, 9.7, .03 HG, 37G, SE AC, CV44, DTT, LMR2, HD oil cooler,V&H classics(I know I should get 2-1)
2007 FLHTCU SERT, SE AC & Fat Cat
09-18-2005, 03:53 PM
#53 (permalink)
He must REALLY understand the inner workings of a bike huh?  Yeah the pump may be gear driven, but its the pressure relief port that is the affected part here...It just forces more oil into the engine workings before the excess can be bypassed.
09-18-2005, 03:57 PM
#54 (permalink)
how cold do you think that has to be?...I was running my bike (with baisley spring) this spring with temps in the 30's and the cold oil pressure wasn't any higher than it has been at startup lately with temps in the 60's...no oil weeping, no leaking or blown gaskets, and my bike has been through the complete range of temps from the low 30's to over 100 degrees this year....sure does quiet the tapping noises I used to get though.
09-18-2005, 09:14 PM
#55 (permalink)
put the spring in yourself. It is very easy!
09-19-2005, 09:13 PM
#56 (permalink)
Ghost Rider - IronButt
Originally Posted by hdmd88
The Fueling pump will flow more oil or I should say it has a larger flow rate. The Basiley spring will give us more constent pressure to the lifters to keep them pumped up but for cooling and lube the fueling pump with it's higher flow rate will do the job better than the stock pump. I used the fueling pump in the strokers I build but I must say it still has 0 to 2 lbs at hot idle....when I install the Basiley spring with the fueling pump the hot idlewent up to 15 to 18 lbs. I think its a good combo but, the spring is my first choice.
Thanks for your posting, Doc. I too was wondering whether a Basiley spring could/should be used together with my Feuling pump. Having 15 to 18 lbs while at hot idle sounds like a great deal. I suspect my oil pressure guage will peg while cold, 60 lbs max., but I could live with that until the engine warms up.
Regards, Carlos
Once a Marine, Always a Marine
1981-2007
'02 Road King Classic * AMS Ported Heads * Andrews 26G cams w/S&S Gears * SE 95" Kit (9.6:1) * Wood Performance K325 A/C * PCIII USB w/Stage I ECM * D&D FatCat exhaust w/quite baffle * 3.37 final gear ratio * VPC w/SE Clutch Spring & Reduced Effort Ramp
09-20-2005, 12:24 PM
#57 (permalink)
Yea, after my Bailsey install my pressure pegs out when cold too...would probably go around twice if the guage didnt stop it!
When I 'act my age'--- shoot me
09-21-2005, 11:11 AM
#58 (permalink)
What kind of oil are you using? I am wondering if it would peg out with a synthetic in the cooler weather. I am thinking about trying the Amsoil straight 60 weight in my 01 road king to see if I can achieve an even quieter running motor than it is right now and then if that doesn't do the trick I will increase the oil pressure with the stronger relief spring.
09-21-2005, 12:27 PM
#59 (permalink)
Good luck.
Well, I have about 2k on my Baisley spring now. The first 1k was mostly around town, then I hit the interstate on the last 2k It started puking oil out the air cleaner. Strange it never did that in the other 53k I rode the bike. I'm beginning to wonder if that spring might be the cat's meow for somebody on the drag strip, but the wrong thing for the guy on the street. I'm sure somebody will tell me I'm wrong....
09-21-2005, 12:30 PM
#60 (permalink)
Highly Seasoned Rider!
HD recommends 60wt oil above 80 degrees F. and 50wt. above 60 degrees F. anyway. I don't know what oil others are using but with 15w-50 or 20w-50 the hot oil pressure with the Baisley spring in my bike is 8 psi idle and 35 psi at 2,000 rpm. It's a little higher when cold. The spring is a good deal but I think it would lead to excessive oil pressure with 60 wt.
Just my opinion, though.
Regards,
NUC
