EagleRiderTheLeatherworksIncKomodoGear.comKewlMetal.comRacer SupplyRosa's CycleHD PipesLawTigersMotorcycle.com
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Twin-Cam 88" Engine Technical Discussions
Old 07-08-2005, 07:15 PM   #16 (permalink)
BlueSkiesandTailwinds
dc3plt is on a distinguished road
This sounds GREAT. Do they have a website????
05' FXDL
CUSTOM CADILLAC PEARL WHITE http://65.38.172.84/forums/member.php?u=17857
V/H BS STAGS
FORCEWINDER
BAISLEY SPRING
CHROME,CHROME,CHROME
THE LIGHT AT THE END OF THE TUNNEL IS JUST A FRIEGHT TRAIN COMING YOUR WAY
dc3plt is offline   Reply With Quote
Old 07-08-2005, 08:01 PM   #17 (permalink)
Don't think so. Call them at 503 289 1251.
Good folks.
Old 07-09-2005, 11:46 PM   #18 (permalink)
rides99fatboy's Avatar
rides99fatboy is on a distinguished road
Do you need to drain the oil?
So is draining the oil necessary? I just changed my and don't really feel like draining it.
rides99fatboy is offline   Reply With Quote
Old 07-10-2005, 04:17 AM   #19 (permalink)
No. You will only use a few ounces outta the bottom of the engine. The rest is in the oil tank or oil pan.
Old 07-10-2005, 06:33 PM   #20 (permalink)
AustinFXDWG is on a distinguished road
Any side effects reported; like oil venting out the aircleaner?
AustinFXDWG
2005 FLTRi Road Glide - 95", SE Flat-tops, SE-AC, SEPro Slipons, Bassani Power Curve True Duals, Dynojet PCIII, HD Oil cooler, Mustang Touring Solo saddle, Fog Lamps, and HogTunes Speaker. Now we';re cruisin'...
AustinFXDWG is offline   Reply With Quote
Old 07-11-2005, 07:38 AM   #21 (permalink)
SYCLONE is on a distinguished road
None on any of my bikes and I beat the crap out of the Night Train.
SYCLONE is offline   Reply With Quote
Old 07-13-2005, 01:49 PM   #22 (permalink)
Registered User
harley4u is on a distinguished road
Just curious...I read the other threads on this topic...are there any instructions of any kind with the spring? Sounds like a simple installation...just wondering if any documentation comes with the spring. Thanks
harley4u is offline   Reply With Quote
Old 07-14-2005, 10:27 AM   #23 (permalink)
Ironbutt
miles to go is on a distinguished road
Yes, it comes with instructions.
Current bikes in the stable:
2003 Heritage Softail Classic
2002 Ultra Classic
2000 XL1200S
miles to go is offline   Reply With Quote
Old 07-17-2005, 09:37 PM   #24 (permalink)
2000FXD
sthorp is on a distinguished road
I don't want to sound too stupid but what exactly does this spring do??
I have intermittent ticking noise and if this would help I would try it. If all it does is increase oil pressure to the upper cylinder head then I wonder if the oil pump is getting weak.
sthorp is offline   Reply With Quote
Old 07-17-2005, 09:54 PM   #25 (permalink)
springer-'s Avatar
What the spring does is increase pressure on the bypass valve. Making it harder to open. If the spring is set for 38lbs, then when the oil pressure hits 38lbs it opens the valve and doesn't allow any more pressure to build up. If you change the spring with a stiffer spring the valve opens up later and cause the oil pressure to rise. If it is set for 40lbs, the valve will then open at 40lbs. This increased oil pressure helps keep the lifters pumped up a little stronger and thus keeps the noise down.
The old way was to stretch a spring but that yields unreliable results. Another way to increase the oil pressure in the twin cam is to simply put a washer between the stock spring and the roll pin that holds it in. This effectively increases the spring pressure. You can actually shim the stock spring for whatever oil pressure you desire. Start with a single .050 washer.
207-242-8374 Cell Phone
207-621-8089 Port Shop/Dyno Shop
Old 07-18-2005, 04:20 AM   #26 (permalink)
Jeff Dodson is on a distinguished road
Is this worth doing on a stck Police RoadKing ?????
Jeff Dodson is offline   Reply With Quote
Old 07-18-2005, 12:04 PM   #27 (permalink)
deuce163 is on a distinguished road
installed one in my deuce this weekend, no more tick, tick, tick..
deuce163 is offline   Reply With Quote
Old 07-18-2005, 04:31 PM   #28 (permalink)
2000FXD
But will increasing the oil pressure have any undesired side effects?? Leaking, pre-mature lifter failure, pre-mature oil pump failure??
Old 07-18-2005, 04:54 PM   #29 (permalink)
Baisley says increase is about 5lbs.
I believe this is less of an increase than some aftermarket pumps.
Old 07-18-2005, 07:50 PM   #30 (permalink)
Well Ok, I am going to order one tomarrow
