» Buyers Guides |
06-03-2006, 06:00 PM
#46 (permalink)
I had a code come up for my fuel injection. I fixed the problem but still get the historic code.
Anyone know how to clear the code history ?
06-10-2006, 01:10 PM
#47 (permalink)
Codes P2061 and P1353
First off....
Wherever it came from and whoever contributed, thank you. This is one of the most informative, simple and useful posts I've ever come across.
Next...
Fault Code P2061 - Front Injector Open/Low EFI
Fault Code P1353Front Cylinder No Combustion EFI
Wouldn't these two go hand in hand? Could this actually refer to something as simple as a bad plug wire on the front cylinder?
Warranty Expired two weeks ago so looking for the simplest solution first.
The symptoms are misfires and engine light occasionally. Thought it was bad gas but it has happened twice now, months apart and once after a fillup, the first time though was a week and 100 miles after the fill up. The problem is even intermittemnt when it happens. Sart off and misfires engine light, 30 seconds at constant rpm, all is ok, light goes out. Accelerate, problem again with same symptoms.
Any help is greatly appreciated!
06-11-2006, 04:52 PM
#48 (permalink)
THANK YOU  i just used it on my bike today cuz it died on me and it came up with the code p1001 and p1003 for my system rely which is what i thunk it might be well low and behold thats what those codes are so i guess ill buy a new relay monday and see if it does the trick thanks again for that post
07-27-2006, 06:03 PM
#49 (permalink)
Eng Light
I have a friend that has a 99 E-Glide with Fuel Injected. When he turns on his ignition switch the engine light comes on as it suppose to, after about 4 seconds goes out. Once he starts the engine, the engine light comes back on for about 6 seconds and goes off. The light does not come on while riding the bike, only after he starts it. The dealer could not find anything wrong. Does anyone have any ideas???
09-07-2006, 03:49 PM
#50 (permalink)
Po113
Thanks for this valuable post. On a recent long trip my check light came on and continued to come on and off for the rest of the ride (2,000+ miles) The bike continued to run fine except for my cruise failing. This morning I checked the codes and got the P0113 (IAT Sensor Voltage open/high EFI) What do I do now? Sensor connection looks OK! Do I simply replace the sensor or clear the code and see if it occurs again?
09-07-2006, 04:30 PM
#51 (permalink)
The best "first" thing to do in this case is to hit the Search link at the top of any page. Putting the P0113 code into it will give you 10 hits, including this one: Diagnostic Trouble Code: P0113.
11-30-2006, 03:01 AM
#52 (permalink)
Great post. Very helpful and useful info. Thanks
05-23-2007, 11:49 PM
#53 (permalink)
GHOSTRIDER LIFE MEMBER
codes
Originally Posted by gsparesa
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
AFR – Air Fuel Ratio
ATS – Air Temperature Sensor
BAS – Bank Angle Sensor
CCM – Cruise Control Module
CKP – Crank Position Sensor. The CKP generates an “AC signal” which is sent to the ECM where it is used to reference engine position (TDC) and speed. Home position established by taking readings off the 22 teeth on the alternator rotor.
DTC – Diagnostic Trouble Codes
ECM – Electronic Control Module. (The Computer) Computes the spark advance for proper ignition timing and fuel control based on sensor inputs (from CKP, MAP & TP sensors) and controls the low-voltage circuits for the ignition coils and injectors. The dwell time for the ignition coil is also calculated in the microprocessor and is dependent upon battery voltage. The programmed dwell feature gives adequate spark at all speeds.
ECT – Engine Coolant Temperature. Sensor also controls the cooling fan relay that provides 12 Vdc to the fans.
EFI – Electronic Fuel Injection
EFP – Electronic Fuel Pump
ET – Engine Temperature sensor
FI – Fuel Injectors
FPR – Fuel Pressure regulator
IAC – Idle Air Control actuator
IAT – Intake Air Temperature sensor
ISS – Ion Sensing System…detonation detection
MAP – manifold Absolute Pressure sensor. The MAP sensor monitors the intake manifold pressure (vacuum) and sends the information to the ECM. The EMC then adjusts the spark and fuel-timing advance curves for optimum performance.
TP – Throttle Position Sensor
VE – Volume Efficiency
VSS – Vehicle Speed Sensor. Used as an input for idle speed control
Thank you............:
yikes:
"KING OF CUBES" - HYPERFORMANCE & R&R CYCLES R&D MONSTER 131" BUILD
INNOVATORS NOT IMITATORS
"YOU CAN'T SOLVE PROBLEMS BY USING THE SAME KIND OF THINKING YOU USED WHEN YOU CREATED THEM"...
08-06-2007, 09:43 PM
#54 (permalink)
Is this thread closed? Or could someone please post the DTC and codes for the 03 RoadGlide? It is not the procedure mentioned nor is it the prior check engine light flash procedure.
10-02-2007, 04:45 PM
#55 (permalink)
2003?
will this work on a 03 RK?
03-31-2008, 05:22 PM
#56 (permalink)
SP = speedometer
T = tachometer
P0501 VSS Low Carb
P0501 VSS Low EFI
FI – Fuel Injectors
Ha I would like to know hqw you came by this info?
I have a 02 FXD and I know the od shows some error codes but I can not find any refferance
in the service man. Thanks
03-31-2008, 06:12 PM
#57 (permalink)
Doof Toll Pimp
The service manual is very carefully written so that you will never find this information.. all it says is to take the bike to your local dealer..
HD even screws you on their cheezy service manual..
You can find this information in the SERT manual and I am sure a few other places...
When you buy a service manual say from General Motors for your truck.. well it comes with all the technical information....
Buy the HD service manual and you get something akin to a cheap A$$ how to manual with very little more than the basic technical information....
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
S&S .570 Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Ported Heads
Gerolamy Dual Throttle Body
V&H True Dual Headers
V&H Python 3 Slip-on Mufflers
Daytona Twin-Tec III Ignitions System
Feuling Oil Pump/Cam Plate
04-21-2008, 02:07 PM
#58 (permalink)
old shovel
a bud of mine has a 99 police special road king with 50,000 miles on it ,we thought it was the bank angle sensor tested it but it was good,we don't have the equipt. to run dognostic ck but this info really helps its pointing to cam sensor,I rode shovels my hole life and this electronic stuff is great till ya start having problems,I have a new street glide and really enjoy riding it,especially when I climbed off a ridgid frame after 17 years,has anyone any quick ideas beside bringing to the dealer,the poor boy way..............
06-16-2008, 10:34 AM
#59 (permalink)
Help!
I've got a 2003 FLHRCi (Road King Classic). Starting last week, I keep having the 'check engine' (why does it look like a car engine, and not a V-Twin, btw??) come on.
I turn on the ignition, then hit the run button. Wait until the check engine light & the one next to it go out, and hit start. About eight or ten seconds later, the check engine light comes on for a few seconds then goes out. I've also glanced down while riding, and occasionally see it lit for a few seconds.
The only noticeable symptom while riding, was on a couple occasions it would "sputter," usually on an upshift from first to second gear.
I tried both sequences listed in this thread, trying to see if there are codes stored.
The first one (set to RUN, hold odometer button, turn on ignition) and I see the same as others have mentioned, which is d01Clr through d10Clr, etc. Apparently that procedure doesn't work on pre-04 bikes, so that's normal.
I tried the second procedure (set to RUN, cycle Ignition in either 5-second on/off intervals, or 4 on / 3 off intervals), and it doesn't show anything either. I just get the check engine light as before (comes on after eight or ten seconds, for a few seconds, then goes out).
Other than taking this to the dealer, or spending big money on a scan tool, is there a solution to pull the code(s)?
Does jumpering the 1 & 2 wires work, as suggested?
