ArnottAirRideAdvanstarMotorcycleShowsStoneyStraps.comEagleRiderMean City CyclesCheapCycleParts.comSpringfield ArmorySportbikeTrackGearCrystal-GloMetalArts
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Twin-Cam 88" Engine Technical Discussions
Daytona Twin-Tec
Old 10-13-2008, 06:22 PM   #1 (permalink)
Deafautotech is on a distinguished road
help....
I did check the run out on crank shaft for gear drive cams swap... it show 0.003 (it will not very correct as perfect zero but that what dial indicator said from 0.000 to 0.003 then 0.003 to 0.000 every crank... is it good to put gear drive kit on it ?????
thanks.
Deafautotech is offline   Reply With Quote
Old 10-13-2008, 10:39 PM   #2 (permalink)
harleys_n_laddertrucks
trucky911's Avatar
trucky911 is on a distinguished road
I would go for it....
Trucky911
trucky911 is offline   Reply With Quote
Old 10-13-2008, 11:41 PM   #3 (permalink)
Disturbed
Traceman
thanks.
That is the max of the spec that came with my cams. I believe you will be ok. Mine .0021 and my back lash onc together was .001. Mine makes very little noise. Good luck wth the install.
Tracy
2004 Ultra with lots of stuff
2003 Heritage with a little stuff
"He who dies with the most memories......Wins!."
Traceman is offline   Reply With Quote
