SportbikeTrackGearMotorcycle.com Classifieds!Wheeldock.comKomodoGear.comDaytona Twin-TecSpringfield ArmoryRacerPartsWholesaleTech N' Cycle GearArnottAirRideBikeBanditHD PipesLawTigers
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Twin-Cam 88" Engine Technical Discussions
RacerPartsWholesale
Old 10-11-2008, 07:52 PM   #1 (permalink)
Mike NY is on a distinguished road
Winter 95" Upgrade questions
I know there are a few threads running already but I have some novice questions.
I have an 06 Softail Deluxe.
I have the Harley 95" Cylinder/Piston kit that I plan on doing myself over the Winter. I also plan on doing the Roller Chain Cam conversion using Andrews 37N Cams.
I want to have the Heads worked a bit and actually tried calling one of the Sponsers here but 2 phones calls went unanswered. I'll try again next week.
I've read alot about Deck Height and Compression Ratio's and all sorts of interesting stuff but at the same time have no plans on becoming a master mechanic so I'll leave that to the Pros.
Question 1: If the heads aren't milled and just Ported/Polished will I be able to use the stock Push-Rods with a .03 Head Gasket?
I'd like to keep the Compression in the mid 9's so will I accomplish this with the Harley Kit - 95"Cylinders. Flat top Pistons.
I hope to keep it as simple as possible. I'm not looking to do hole shots but a little more umph would be nice.
Any other info or advice would be helpful as well..
Mike
NY
Mike NY is offline   Reply With Quote
Old 10-11-2008, 08:22 PM   #2 (permalink)
Johnny Come Lately
Gulfstream's Avatar
Yes, the stock pushrods can be reused if you don't mill the heads much. I think you'll have a hard time reaching mid 9's for compression without milling the heads slightly as the stock heads generally run about 86cc's...you would probably be looking at about 9.2:1 with that combo. An 81cc chamber will get you to 9.7:1 which is the sweet spot for that cam (figuring a 0.0" deck height).
John Levanger
Old 10-11-2008, 08:49 PM   #3 (permalink)
Thanks for the response.
I imagine the people doing the Porting would need to know the Deck Height before I send them the Heads.
I was hoping to avoid Adjustable Push Rods just to make the job easier but I guess what ever it takes to get it done right..
I'm looking forward (I think) to taking this on..
Mike
NY
Old 10-11-2008, 09:52 PM   #4 (permalink)
harleys_n_laddertrucks
trucky911's Avatar
trucky911 is on a distinguished road
Keep us posted on your build...I'm think of doing the same this winter also...
Trucky911
trucky911 is offline   Reply With Quote
Old 10-11-2008, 10:33 PM   #5 (permalink)
I paid.........did you??
MaineUltraClassic's Avatar
MaineUltraClassic is on a distinguished road
www.bigboyzheadporting.com
If you are going to do this build, do it right..............have the heads cc'd and milled to equal the compression and set it at the 9.8-1 that the 37's like. Do it right the first time so you won't regret it later and tear it all apart again.
Give Bean a call and he'll take care of you.
Steve
Powered by Big Boyz, Woods, Doherty, S/E, Fatcat, & Cometic
MaineUltraClassic is offline   Reply With Quote
Old 10-12-2008, 03:33 AM   #6 (permalink)
towboattrash34 is on a distinguished road
well i have a set of joe mondello heads for sale for a 95" 89cc 10.5.1 comp set up for JE 10.25.1 pistons... 2,000 miles on them
06 Dyna Lowrider
95 build W/GMR Welded Heads
SEII's w/stage1 and SERT
J&E pistons
Woods TW-7H cams
Built by me.
towboattrash34 is offline   Reply With Quote
Old 10-12-2008, 08:21 AM   #7 (permalink)
Hillsidecycle.com is on a distinguished road
Heads
Our in-house cylinder head mods,will most certainly enhance the existing power of that build, and would also suspect an increase in fuel economy as well.
Palmer Bros.
Hillside Motorcycle & Machine
V-Twin Performance Center
Munnsville, N.Y.
315-495-6650
www.hillsidecycle.com
"Repairing Broken Torque Curves Since 1982"
Land Speed Record Power
Hillsidecycle.com is offline   Reply With Quote
Old 10-13-2008, 11:37 PM   #8 (permalink)
I had a chance to speak with Bean over at BigBoyz today. First off he was great to talk with and spent some time on the phone explaining all kinds of neat stuff to me.
It looks like I'll be sending my heads out in a few weeks for him to work on. I'll try and keep this thread up to date as I move along. I'll do my best to take pictures as well since I know seeing is believing..
Mike
NY
