KewlMetal.comEagleRiderArnottAirRideHD PipesProCharger.comDaytona Twin-TecCellino&Barnes Motorcycle AttorneysCrystal-GloSpringfield ArmoryPro PadRacerPartsWholesaleMean City Cycles
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Twin-Cam 88" Engine Technical Discussions
SportbikeTrackGear
Old 08-27-2008, 10:20 PM   #1 (permalink)
ginohd is on a distinguished road
Pinion Runout?
OK, next week I plan to pull off the cam cover and have a look at the cam chain tensioners at 42,000 miles. I would like to go gear drive cams if pinion runout allows. What is the maximum acceptable runout to allow the change to gear drive cams? Thanks
Gene
2001 FLHTCUI
42,000 mi.
ginohd is offline   Reply With Quote
Old 08-27-2008, 10:23 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
.003 For gear drives.
HILLSIDE CYCLE 117
Hillside custom heads, S/E billet cam plate/oil pump, S/E 4.375 forged crank Darkhorsed, Axtell cyls and pistons, S+S p-rods and roller rockers,S/E CV51 carb, DTT ignition, Black Fatcat w/perf baffle, Pro Clutch,Woods TW9BG cams and KF325 filter
TXCHOP is online now   Reply With Quote
Old 08-28-2008, 06:14 AM   #3 (permalink)
SHOOTER15 is on a distinguished road
Smile Heres what I found out......
Gene
2001 FLHTCUI
42,000 mi.
I put S&S 510's in my bike and it had.0015 run out,sounded like a "THRESHING MACHINE" when it warmed up !....yanked 'em out and went to the new style cam plate with 37n Andrews cams,LOVE THE DIFFERENCE !.......am told by those who allegedly know that .003 run-out is allowable......in my case it was TOO DAMN NOISY at half that much ....I've also put the gear drive cams in bikes with .002 and they were quiet...go figure !.
SHOOTER15 is offline   Reply With Quote
Old 08-28-2008, 08:09 AM   #4 (permalink)
some times you get a bad gear or you need to go oversize or undersize. I have or at least had .0015 when I did mine 25,000 miles ago (61,000 total) and they have remained quiet and you can not tell it is gear drive by hearing it run. My gear lash was spot on too.
Old 08-30-2008, 06:44 PM   #5 (permalink)
Taterdog's Avatar
Taterdog is on a distinguished road
You can also call Andrews and discuss with them. They will give you some good guidance on what to look for and the tolerances required. Can also give you an idea of what cam you should go with based on how you want to ride.
2000 FLHTCI
Rinehart TD's
Andrews 26G Geared Cams
HD Stage 1 Download with PCIII
Ness Big Sucker
Michelin Commanders
Age is an issue of mind over matter. If you don't mind, it doesn't matter. -- Mark Twain
Taterdog is offline   Reply With Quote
