Daytona Twin-TecMotorcycle.com Classifieds!Motorcycle.comKomodoGear.comKewlMetal.comStoneyStraps.comRosa's CycleHD PipesArnottAirRideProCharger.comWheeldock.comMetalArtsSpringfield Armory
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Twin-Cam 88" Engine Technical Discussions
BikeBandit
Old 05-10-2004, 09:03 PM   #61 (permalink)
03wglide is on a distinguished road
Thumbs up
I just changed my oil today using the filter box, works like a charm. The box slips in behind the filter perfect! Not a drop of oil on the eng. mount! Thanks for the tip.
03wglide is offline   Reply With Quote
Old 06-01-2004, 09:42 PM   #62 (permalink)
Madkeltic is on a distinguished road
Alright, I am sure that I must have missed something, or the rest of you guys are used to spilling lots of oil. I just tried this technique yesterday and it was helpful, but I still ended up getting oil on a lot places. I'll give it a try again the next time but if I end with as much oil as I got this time, I'll go back to my okd method of cutting some cardboard to fit. Beer boxes do have other uses ya know.
Madkeltic is offline   Reply With Quote
Old 06-04-2004, 04:14 PM   #63 (permalink)
Curve the end of box slightly to make a trough after you get it behind the filter. Make sure the end sticks out beyond the voltage regulator. Remove the filter slowly so you don't a surge of oil all @ once.
03
Old 06-13-2004, 01:45 AM   #64 (permalink)
Cabo Wabo '06
namooz's Avatar
namooz is on a distinguished road
Yes
That's a great idea about cutting a section out of the filter socket. I am definately in on that one. Thanks for the pic!
05' Softail Deluxe EFI/Black Cherry Pearl
Build, blueprint, & fine tune
95" KB 10.5:1 pistons (10 to 10.2 dyn. comp.)
.030" commetic/.035" quench
HD cyl's .001" piston fit
06' modified heads
Black Diamond high lift valve springs
perf valve job (Boyd's)
TW55 chain drive cams
S&S adj. pushrods
SE heavy clutch diaphram spring
polished TB/manifold
Doherty w/Power Vents
Pro Pipe HS/BSS baffle mod/Dyna stock mod muffler
PCIII & Dyno
Jagg oil cooler
93HP/98TQ
namooz is offline   Reply With Quote
Old 06-25-2004, 07:50 PM   #65 (permalink)
MaddMax
Damn...didn't know you were s'posed to change it...thanks for sharing the tip
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in sideways, thoroughly used up, totally worn out and loudly proclaiming.....WOW....What a Ride!
FM3
MaddMax is offline   Reply With Quote
Old 07-13-2004, 07:14 PM   #66 (permalink)
The Specialist's Avatar
The Specialist is on a distinguished road
Funny, I have been doing it that way for years. ( Oil filter box )
And what did I see at my local HD dealer a few weeks back.
A Plastic type pan with a spout that fits right under the filter and routes the oil away just like in your photos above.
It is under twenty bucks and sold through one of the big vendors like drag or custom chrome.
Somebody making some $ on the idea.
The Specialist is offline   Reply With Quote
Old 07-20-2004, 04:09 PM   #67 (permalink)
ClassicRider's Avatar
ClassicRider is on a distinguished road
Originally Posted by mtucci
Habanero Kid
Gots to hand it to you for that fine demo. I'm impressed with the simplicity
of it all!! And a big thank you for sharing it! Yep, I'll be using this method
on my next change, cause I kinda made a mess removing that sucker oil
filter last time.
HEY I COPIED ALL OF THOSE PICTURES AND EVERYTHING.....very nice...but the problem WAS and IS on my Road King Classic....with AN OIL COOLER INSTALLED it don't WORK!!!!!!!!!!!!! But what does work is taking a 8.5" long X 5.5" wide rigid cardboard and sort of making a half circle out of it.....and then where the oil adaptor piece that is chrome comes out to accept the oil filter that is where you put the 5.5" wide portion of the rolled up cardboard underneath it tight....THEN.....letting the cardboard come out 8.5" perpendicular to your tire.....meaning that now when the oil filter is unscrewed and you begin twisting it off....the oil will flow out to the side of your bike and with the 8.5" length it will allow the OIL that comes quickly out of that filter to miss everything below and fall neatly into the pan......THE ABOVE WORKS very well when you have not installed an OIL cooler but, I FOUND OUT QUICKLY (in the field) that it's not going to work when you have that oil cooler attached below the oil filter.....
HOPEFULLY This helps those of you that are running the oil coolers....if you are so inclined to try this....just an idea.....also make sure the cardboard you use is rigid enough....that's important.....
ClassicRider
ClassicRider is offline   Reply With Quote
Old 07-21-2004, 05:42 AM   #68 (permalink)
FXDRYDR is on a distinguished road
Originally Posted by Habanero Kid
and you're done........
Hey H -
Great post!! Loved it!
FXDRYDR is offline   Reply With Quote
Old 08-05-2004, 06:55 AM   #69 (permalink)
UltraGlideGuy is on a distinguished road
Great Info Thanks
gonna try it tonite
UltraGlideGuy is offline   Reply With Quote
Old 08-29-2004, 08:31 PM   #70 (permalink)
SITnLO is on a distinguished road
I can't seem to get the pics??
I could of used a good tip today when I changed the oil.
Can someone please send me the pics if they have them.
Rick
SITnLO is offline   Reply With Quote
Old 08-30-2004, 01:45 PM   #71 (permalink)
Zeeb is on a distinguished road
Thumbs up TC oil change trick with a twist
H Kid, Awesome tip! I ran into a problem on my 05 FLHT because the regulator is larger and oil won't run up hill and over it, so I found and old shampoo bottle and cut the bottom and the top out and a slit down the side and coupled with your box tip, I didn't get a drop on the bike. Thanks again Zeeb.
(see attached)
Zeeb is offline   Reply With Quote
Old 09-16-2004, 02:13 PM   #72 (permalink)
Smuggler
Hey HBK,
I've been using that tip for years. I never even realized the benefit of sharing it. Thanks!
P.S. additional tip: Take a tiny piece of duct tape and place it on the upper side of the filter box. it helps hold the box from any chance of slipping or being accidentally moved while working on the filter and creating the mess you were trying to avoid. Also, that filter wrench with the slot is specially made. I once tried cutting a slot in a standard one and it lost its strength to grip those tightly installed filters.
Old 09-16-2004, 04:18 PM   #73 (permalink)
Springer
Rich g is on a distinguished road
I wish I would have read this before I did my first oil change, what a mess. :p
Rich
How strange is the lot of us mortals! Each of us is here for a brief sojourn;for what purpose we know not, though sometimes sense it. But we know from daily life that we exist for other people first of all for whose smiles and well-being our own happiness depends.
--Albert Einstein
Rich g is offline   Reply With Quote
Old 10-18-2004, 04:47 PM   #74 (permalink)
col_kurtz is on a distinguished road
My voltage regulator gets in the way on a Road King.
- Man is the best computer we can put aboard a spacecraft and the only one that can be mass produced using unskilled labor. - Werner Von Braun
col_kurtz is offline   Reply With Quote
Old 01-13-2005, 07:55 PM   #75 (permalink)
Broken Spoke's Avatar
Broken Spoke
Keep your engine clean with this tidbit. The pics and bike are not mine. They came from another board. Instead of trying to explain how to do it, photo's were supplied.
Step 1 - remove the filter from the box.....then........
[b]I'm just thankful that H-D didn't think of this great idea. Wouldn't bother them at all to charge $12.95 or whatever for a piece of damn paper.
Thanks for the post and thanks to whom ever is responsible for the idea!!!![/B]
2006 Black Bagger
Stage One
K&N
PCIII
V&H True Dual Headers
Screaming Eagle Mufflers
Now, smok'em till they melt!!
Broken Spoke is offline   Reply With Quote
