American Side Road CycleProCharger.comCustom DynamicsBikeBanditMotorcycle.com Classifieds!
Stainless Ride Specialty AccessoriesOriginal Bike SpiritsFuel Moto
Leslie Kay's
Old 01-31-2003, 09:12 PM   #1 (permalink)
JaxSoftail
twin cam dyno results
Just looking for input regarding these results - checking to see if they are typical for Stage I Mods. To me, peak power (75.2 HP) looks respectible, but peak torque (81.5 lb-ft) is a little low. The shape of the torque curve looks pretty good though, being essentially flat.
2002 FXST (TC88B)
VH BigShot Staggereds
NESS Big Sucker
DynoJet Thunderslide
JaxSoftail is offline   Reply With Quote
Old 02-01-2003, 03:34 AM   #2 (permalink)
xrystl
Hi Jax -Just looking at your dyno sheet , the HP is good , and about what you would expect , IMO the torque can use some work - the torque peak is a bit too high in the rev range , if the torque peak was bought back to about 3300rpm you will lose the dip that starts to appear at about 2700rpm . A little bit of tinkering would do it , but be happy with it because when you are cruising you are very much in the torque band , it should be a good ride .
Old age and treachery will always overcome youth and skill
xrystl is offline   Reply With Quote
Old 02-01-2003, 03:53 AM   #3 (permalink)
Paladin1 is on a distinguished road
Jax, I have a 02 Road King, with EFI. I understand they produce less power, so don't know if this helps, but after a stage 1 with a factory reflash on the chip, the dyno showed 68 hp, and 78 tqe.. It was not tuned on the dyno, rather that was a base line before a stage 2 kit. After stage 2, 82 and 92. Based on that, I suppose you could guess you either have high hp or lower tqe (kinda like optimist vs pessimist??). No idea how much the efi affects it. good luck, greg
07 Road Glide
07 FXD
06 Street Rod
02 Road King (4 sale)
47 Flathead (45)
Paladin1 is offline   Reply With Quote
