Battery ok?- clicking noise but will not start : V-Twin Forum: Harley Davidson Forums
Old 10-19-2006, 11:37 PM   #1 (permalink)
morpha wants to know Dino or Syn?
Question Battery ok?- clicking noise but will not start
I recently discovered that my nephew may have drained my battery...indicator lights work and headlamp turns on. Charged the battery on my charger and...
Trying to start the bike all I get is an annoying clicking noise and no rumble!
could the issue be non-battery related? how can I tell if I am flooded?
advise please, can't stand seeing the sporty sitting and not movin'
morpha is offline   Reply With Quote Quick reply to this message
Old 10-19-2006, 11:49 PM   #2 (permalink)
Bubba Neil wants to know Dino or Syn?
How old is the battery? How long did you charge it & was it 2 amps, 6 amps or a trickle charge.
I like to charge them at 2 amps for a while to bring them back.
Bubba Neil is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 12:08 AM   #3 (permalink)
Ironbutt
MilesToGo's Avatar
If the motor is not turning over then it's most likely your battery. If you've already tried to charge the battery and checked the connections, then take the battery somewhere and get it checked. I'd bet it's either not charged completely or it's bad.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 10-20-2006, 02:28 PM   #4 (permalink)
raig wants to know Dino or Syn?
Check the connections to the battery. Mine did the same thing this summer, the positive connection came loose, lights would come on till I went to start it then click nothing. Tightened it up, worked fine.
I hope yours is that easy.
raig is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 04:39 PM   #5 (permalink)
dzlfitr wants to know Dino or Syn?
Gotta agree.... check ALL connections. Disconnect ground from
battery, and check, clean, grease, and tighten starter connections.
Same with battery. Go from there. Don't throw money away
if you don't have to.
dzlfitr
dzlfitr is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 07:03 PM   #6 (permalink)
ORIGINAL DOOF BABE
Lady Godiva's Avatar
Location: Hilton Head Island, SC (Formerly from Lansing, MI)
Lady Godiva wants to know Dino or Syn?
Gotta go with the battery here also. Usually that "click click click" noise from the starter means battery's croaked or you're not gettin' any juice.
Laurie T.
2000 FLHRCI Road King Classic - 95" Big Bore
"I refuse to have a battle of wits with someone who's unarmed"
(and I have 43 points on the top of my head)
VTF Photo Album Link: http://www.v-twinforum.com/gallery/s...page=12&sort=3
Lady Godiva is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 12:29 AM   #7 (permalink)
21943 wants to know Dino or Syn?
It is your battery, it may have 12 or even 14 volts to light up the little bulbs, but not the Amps to cranks the engine...
BTW, get a battery tender (original brand) or Harley's OEM, will be the best money spent, particularly if your bike has an alarm system.
Glide
21943 is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 03:15 AM   #8 (permalink)
godzilla22 wants to know where he is and how he got here
If you're not sure if it's the battery...Jump it! You can jump it with any 12 volt car. DO NOT HAVE THE ENGINE ON THE CAR RUNNING!!! Connect the cables to the car, Then connect the ground cable to the Neg. terminal on the bike battery
Then CAREFULLY connect the hot cable to the Pos. terminal on the bike battery... Hit the starter on the bike. If it's your bike battery the bike will start. If it's anything else...It won't.
Make sure you DO NOT have the engine running in the car 'cause it will burn out the voltage regulator on the bike. I use a car battery at my shop for jumping dead bikes all the time and have never had a problem.
godzilla22 is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 02:25 PM   #9 (permalink)
murphdog's Avatar
murphdog wants to know where he is and how he got here
You'll want to connect the positive jumper cable to the dead battery first, then to the good battery. Next connect the negative jumper cable to the good battery, then to a ground on the dead vehicle (not the battery terminal).
If you connect the positive jumper cable to the dead battery last, you risk drawing an arc that can cause the dead battery to explode. You also risk accidentally touching the positive jumper cable to something other than the positive battery terminal on the dead vehicle which will result in significant arcing.
murphdog is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 04:27 PM   #10 (permalink)
Roadie wants to know Dino or Syn?
batteries
Here is a little more for you. just because the lights work doesn't mean that the battery has enough cold cranking amps to turn the engine over. Take you bettery to an auto parts store and have it load tested. Then check the measured load (amps) against the rating oh the battery.
Another was to test is to put a volt meter on the battery with the engine off. You should be getting at least 12 volts. Then when you start the engine up you can remeasure the battery with the engine running and you should get more then 12.5 volts.
The measurements I speak of will also tell you if your charging system is in proper order. Hope this helps.
Roadie is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 04:35 PM   #11 (permalink)
sonoffatboy's Avatar
sonoffatboy wants to know Dino or Syn?
well seeing yer riding a sporty and its not fuel injected...bump start the thing...
CHARTER MEMBER OF THE SIXTY EIGHT
sonoffatboy is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 05:20 PM   #12 (permalink)
Obsolete Rider
RidingJerry's Avatar
RidingJerry wants to know Dino or Syn?
Jump it with another battery as stated above.
If the juice from a 2nd battery won't make the starter engage then you
may have a loose/bad connection.
1998 Obsolete EVO Springer
Now boasting the Al Gore enviromentally friendly engine.
In the South, it is "Merry Christmas".
RidingJerry is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 05:29 PM   #13 (permalink)
bill corkey's Avatar
bill corkey wants to know Dino or Syn?
definitely not flooded
Flooding is not your problem. doesn't come into play if engine not turning over.
Follow the battery charging advice above and jump from a car as advised above.
Could easily be a loose connection.
bill corkey is offline   Reply With Quote Quick reply to this message
