Roadglider,
Can you give the specifics on your stage III motor? What is you compression ratio?
Do you have a beefier starter? You may need to add compression releases to the heads.
On the other hand, if your battery needs constant charging, I would inspect all elements of the electrical system first.
regards,
wyo
