CycleGear.comPowerstar SparkplugsStainless Ride Specialty AccessoriesSportbikeTrackGearMotorcycle.comBikeBanditDiamond Bar ChoppersProCharger.com
SportbikeTrackGear
Old 06-14-2006, 05:15 PM   #1 (permalink)
Monstermile's Avatar
Monstermile is on a distinguished road
Before 25* injectors have them check intake seals
As I discussed in a few other threads I had major issues with surging, stalling, popping, coughing, bucking when I bought my Road King Custom a few months ago. Had the 25* injectors done and the new map for them. Fixed a little of the cold starts and popping but still ran bad. Had it in again the other day and they checked and replaced the intake seals. Problem solved for the most part. Runs alot better. No more bucking and surging at low speeds. High speeds I don't get the surging when I let off the throttle. Still doesn't run 100% but it is 100% better then it was before.
You might want to mention the intake seals before they want to swap the injectors if you are having similar problems. Which apparently alot fo people are. I am going to see if there is any chance of them putting the 6* injectors back in to see how it runs.
Monstermile is offline   Reply With Quote
