Dan Vance Racing
Old 06-13-2006, 04:19 PM   #1 (permalink)
04FXDLI is on a distinguished road
Question no fuel pump
Heres the low down went for ride about 75 80 miles. Go to eat at place just down the road from the house bike starts no problem, get to the house and bike dies like it ran out of gas. I had filled up before ride but checked level anyway 3/4 tank. Well it was real hot out so i check the fuse's, there ok but the bike fired up. Pulled it into garage well that was not the problem went to go get some beer 3 hours later bike would not fire. Noticed no weeeerrrrrrr from fuel pump so i post under dyna get a few hit and try all sugeestion. Pull up trouble code from here it throws p1001 and 1003 system relay well went to HD today got new relay put it in still nothing. Pull the battery let it sit put back nothing. Open tank to see if loose wire in tank near pump nothing, all looks good so any other suggestion to try went over manual on trouble shooting did all i can without computer got appointment with dealer tuesday.
04FXDLI is offline   Reply With Quote
Old 06-13-2006, 04:34 PM   #2 (permalink)
bikernut is on a distinguished road
I had a prob once, the tank instrument panel was pushing on the fuel pump connection causing a broken circuit,repositioned the wires and all has been fine since
bikernut is offline   Reply With Quote
Old 06-13-2006, 04:43 PM   #3 (permalink)
ill try it thank you
Old 06-13-2006, 05:04 PM   #4 (permalink)
ok no luck with that unless the wires are fried and i cant tell pulled up the trouble code again and got no rSP just looked at the post on it and saw no referance to that code under the first p
Old 06-13-2006, 05:14 PM   #5 (permalink)
no rSP means im a dumb a$$ and didnt have my run stop switch in the right position
Old 06-14-2006, 09:12 AM   #6 (permalink)
14-O is on a distinguished road
Here's yer sign.
14-O is offline   Reply With Quote
Old 06-14-2006, 10:40 AM   #7 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
Hee Hee.
Old 06-14-2006, 12:03 PM   #8 (permalink)
pws
pws is on a distinguished road
Originally Posted by 14-O
Here's yer sign.
pws is offline   Reply With Quote
Old 06-14-2006, 12:12 PM   #9 (permalink)
Hellbound Train
csoday's Avatar
Thanks for coming back with the fix even if it wasn't broke. It takes balls to do that around here.
Chuck Soday
GO FAST
'03 FXSTBI 103" Stroker
112 hp -- 121 tq
100% S.E.
My V Twin Gallery
Old 06-15-2006, 09:35 AM   #10 (permalink)
Im a glutten for punishment what can i say i like the pain
Old 06-15-2006, 10:10 AM   #11 (permalink)
Arse Hole and Good at it
06 Nighttrain's Avatar
06 Nighttrain is on a distinguished road
Now thats some funny sh*t . Glad you got it fixed though.
95"
SE 257 Cams
SE High Comp Pistons
Feuling Super Pump
Feuling HP+ Lifter
Ported Stock Heads
RB Racing LSR "C" Turn Out
Twin Scan+
3.37 Gearing
58mm Invert Forks, 5* Rake
The Hot Rod; http://photobucket.com/NightTrainTimmy
06 Nighttrain is offline   Reply With Quote
Old 06-23-2006, 07:58 PM   #12 (permalink)
Ok well got the bike back from the dealer and it turns out that i must have pinched a wire when A. i installed the tank lift or B. when the recall on the throttle cables came out and i pulled the tank to check for myself but all is well back on the road and riding thanks again for the help
