I was a little naive when I purchased my FLHTCUI this spring. My last bike, a 2K RG had a stage 2 big bore upgrade done to it by its previous owner so I wanted the same thing on my new Ultra. I held off on the cams but did opt for the dealer's advertised Stage 1 Big Bore upgrade along with SEII slip-ons. The dealer told me the sale they had during the winter was over but said they'd give me the same deal because I was incorporating it into the bike purchase. When I took delivery, the parts weren't itemized on the invoice, it just said Stage 1 Big Bore. I knew up front I was getting bored stock cylinders vs new HD ones but everything else is new SE items.
You might have read my posts in the EFI forum about my dyno results and my questions about a SERT. Hals speed shop recommended a DFO after my dyno run because the SE Stage 1 1550 download had it running pretty lean. I told them that I wanted to upgrade the heads and cams next year so I was more interested in a SERT. They asked what kind of pistons did House of HD use, flat top or domed? Huh? I assumed flat tops because that's what every one on the forum here seemed to have. I went back to House and asked for the part inventory of my upgrade. Turns out they used the 22661-99A High Compression cast piston kits. No wonder my bike is pinging. 10.25 to 1 compression ratio. I have to change them if Iwant to go to Hal's custom heads adding 350 to my already high upgrade quote.
Now I'm reconsidering the head work. Anyone else have these pistons in your build? Are you happy with the results after you got them dialed in? I'm kinda lost as to which way to go now. My goal is low end torque instead of high horspower. I want it to pull hard from 2500 to 4000 RPM. That's where I have the most fun.
Here is the thread I posted on my Dyno run.
Advice please. (Thanks grock and megaglide for your help in the EFI forum)
'05 Sunglo Blue FLHTCUI - SE 95 inch Stage One with cast hi-comp pistons, SE Slip-ons, SE Air Filter, SERT 4.50, Mustang Seat, Heated Grips, 9" Windscreen. an empty wallet and a big s**t eating grin on my face
