SportbikeTrackGearCycleGear.comStainless Ride Specialty AccessoriesMotorcycle.com
Old 06-27-2005, 12:17 PM   #1 (permalink)
fcoxwell is on a distinguished road
Steering head adjustment tool?
What are you using to adjust the steering head nut for the fall away check? The manual says to use a 16" piece of drill rod. What is drill rod?
Frank
fcoxwell is offline   Reply With Quote
Old 06-27-2005, 12:23 PM   #2 (permalink)
XLIII
MegaGlide's Avatar
MegaGlide is on a distinguished road
It's a piece of pretty tough (not hard) steel, round like a drill bit, but no flutes. A good tool supply place should have it.
Dave
I mock, therefore I am.
MegaGlide is offline   Reply With Quote
Old 06-27-2005, 01:23 PM   #3 (permalink)
Kags is on a distinguished road
Dag gon I use a coat hannger.
Kags is offline   Reply With Quote
Old 06-27-2005, 05:29 PM   #4 (permalink)
Thorns's Avatar
Thorns is on a distinguished road
I use a yard stick clamped to a small step stool. Works for me!
Thorns
Thorns is offline   Reply With Quote
Old 06-27-2005, 05:44 PM   #5 (permalink)
XLIII
MegaGlide's Avatar
Thorns
Does the step stool keep the yard stick from flexing when you whack it to turn the nut?
Dave
Old 06-27-2005, 07:47 PM   #6 (permalink)
Fall away only take a peice of tape on the fender & a fixed point at the center mark. Where do you beat on anything?
Old 06-27-2005, 08:37 PM   #7 (permalink)
Retired Navy - MCPO
Ed Y's Avatar
Frank,
I've got an old cheap, long screwdriver with a round shaft that I just ground down to fit the opening. Been using it for years.
Ed Y
2002 FLTRI
I yam what I yam.
Ed Y is online now   Reply With Quote
Old 06-27-2005, 08:59 PM   #8 (permalink)
XLIII
MegaGlide's Avatar
Can we start a reading comprehension forum?
When the light doesn't even go on when you mock the answers...
Dave
Old 06-27-2005, 10:14 PM   #9 (permalink)
Oh well I guess I just dont get it.
Old 06-27-2005, 10:31 PM   #10 (permalink)
Rooster
I have a long thin pin punch that works well.
Some of you need to re-read the original question. He is not asking how to measure the fall away, but how to adjust the nut when the fall away needs to be adjusted.
Riding in Paradise
Rooster is offline   Reply With Quote
Old 06-27-2005, 10:31 PM   #11 (permalink)
XLIII
MegaGlide's Avatar
...adjust the steering head nut...
Is it beginning to come into focus now?
Dave
Old 06-27-2005, 10:35 PM   #12 (permalink)
Thorns's Avatar
"What are you using to adjust the steering head nut for the fall away check? The manual says to use a 16" piece of drill rod. What is drill rod?"
FXDL - I use a socket to tighten or loosen the nut to achieve the correct "fall away" spec. I measure the fall away with the yard stick clamped to a step stool. :2flips: On a FXDWG model, the adjuster nut is tightened with a drift pin after loosening the top nut. :2flips:
Thorns
Old 06-27-2005, 10:43 PM   #13 (permalink)
XLIII
MegaGlide's Avatar
Hey, Thorns, no fair changing your post like that after you finally figured it out!
Dave
Old 06-28-2005, 10:09 AM   #14 (permalink)
Thorns
Thats what Im talking about. No special tool needed, just a socket & hex wrench.
Old 06-28-2005, 10:26 AM   #15 (permalink)
Thorns's Avatar
LOL...Meg it's ok.
Thorns
