JardineProducts.comDiamond Bar ChoppersPro PadSportbikeTrackGearLeslie Kay'sMotorcycle.com Classifieds!
AdvanstarMotorcycleShowsCustom Dynamics
Old 04-06-2006, 06:27 PM   #151 (permalink)
Seasoned Prime Member
RoadKingCurley is on a distinguished road
I use Amsoil now. Buy it from one of the sponsors. Like $6.25 qt. I usually buy it by the case or gallon. Filters, gear oil, all at a discount. Good stuff. I used to use Red-Line but it got too expensive and to hard to find.
RoadKingCurley is offline   Reply With Quote
Old 04-07-2006, 11:09 AM   #152 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
I've heard that Amsoil is very good.
Sure wish they would sell Amsoil locally. I only use products I can get anywhere in a store when I need them.
Old 04-07-2006, 12:38 PM   #153 (permalink)
Pimp Daddy
sr1032 is on a distinguished road
They are sold locally, especially where you live. Just go on Amsoil's website and you'll be able to find a local retailer that will give you the discount if you have a preferred member card.
Procrastination is like masturbation, seems like a good idea at the time but in the end your only f#@$ing yourself!!!
1981 FXB Sturgis & 2004 Dyna Wide Glide
sr1032 is offline   Reply With Quote
Old 04-08-2006, 07:07 PM   #154 (permalink)
ratrider is on a distinguished road
Damn, can't even remember what the original question was. Started reading when it was 4 pages and now it's what, 11??? Baisley spring?
My bike is quiet so I don't think I will try this but I was wondering. If the new spring increases the relief valve opening pressure by 5 pounds or so it will benefit only after the stock pressure is reached. And I thought with all the reports of single number pressures at idle that the new spring would only benefit at higher rpm's. Or is that measuring pressure at a different location than a typical pressure guage?
_______________________________________
DOH! NUTTS! Is there nothing they can't do?
ratrider is offline   Reply With Quote
Old 04-08-2006, 07:37 PM   #155 (permalink)
It raises pressure across the board....at idle and at speed. In your case, though, If it ain't broke, don''t fix it.
Old 04-17-2006, 05:09 PM   #156 (permalink)
superk13 is on a distinguished road
I installed my Baisley Spring this weekend and the bike still sounds like a typwritter. Don't have a gauge so no way for me to tell if the pressure increased by 5 lbs.
Question? Why do some get great results while others hear/see no difference?
99 Road King Classic Injected
95ci
Wisco 9.5:1 Pistons
S&S 510 Gear Cams
S&S Adjustable Push Rods
SE High Flow AC
Stage 1 ECM download
Fueling Oil Pump
Ported and Polished OEM Heads
Power Commander III USB
D&D Fat Cat 2 into 1 w/ falsee
superk13 is offline   Reply With Quote
Old 04-17-2006, 05:39 PM   #157 (permalink)
george douglas's Avatar
I sell Amsoil to forum members at dealer prices right from our closest warehouse. If you want to buy locally I may be able to find you a shop or store that carries Amsoil, but you will pay a couple dollars a quart more than my prices.
for more info.
What's in your Motor? http://www.oilhelp.com/misc-images/g2156.pdf
Old 04-17-2006, 06:21 PM   #158 (permalink)
Ironbutt
I find it interesting how they recommend changing primary and transmission fluids prior to "winter or extended storage." Do any of you guys do this? I just stick with the mileage interval and never had any problems. I really can't see how that oil sitting still for a couple of months is going to change anything.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
MilesToGo is online now   Reply With Quote
Old 04-17-2006, 06:33 PM   #159 (permalink)
2000FXD
sthorp is on a distinguished road
I stick with the mileage interval also, can't think of any reason to do otherwise.
You are entitled to your opinion, even if it is wrong.
sthorp is offline   Reply With Quote
Old 04-17-2006, 08:01 PM   #160 (permalink)
DILLIGAF
berserker's Avatar
Old oil is supposed to be corrosive.
Old 04-17-2006, 08:07 PM   #161 (permalink)
Harley must feel that their oils rust fighting ability is not up to par so they don't want you to take a chance of letting oil set on the gears that may be saturated with corisive condensation. It's called CYA!
for more info.
Old 04-17-2006, 08:25 PM   #162 (permalink)
Ironbutt
Okay, good thing i don't use the HD stuff. What's Amsoil's position on this?
2009 Street Glide
Old 04-18-2006, 09:44 AM   #163 (permalink)
Amsoil's position on the engine oil is up to twice the oil change interval of what HD recommends or one year what ever comes first. I don't believe this applies though to the primary and tranny, which they state 10,000 miles for the primary and 20,000 for the tranny with no disclaimer like Hd uses.
for more info.
Old 04-18-2006, 04:42 PM   #164 (permalink)
Lazy 98
Mike H.'s Avatar
Mike H. is on a distinguished road
Ok I've never tried AMS oil and don't know where to get it in Hawaii, but I CAN tell you that my bike runs COOLER on Syn3 than regular dyno oil!
'06 Heritage Softail Classic
Heads by GMR
Revolution 98" w/CP flat tops @ 9.7:1(9.28 corrected)
Andrews 37G
Mikuni 45 w/ Bobby Wood 325 CFM
V&H Propipe
LMR II oil spring, GMR lifetime lifters
Crane HI-4TC ignition
SE clutch spring, Hayden M6
okole tuned to 94hp/98tq (yes, that is measured)
Mike H. is offline   Reply With Quote
Old 04-27-2006, 08:42 AM   #165 (permalink)
McClendons
For those with the spring, what are you now seeing as oil presure once warm (say at idle and at 2500 RPM or so). Just installed mine, and the presure is higher than I expeced, so want to make sure I do not have something wrong.
McClendons is offline   Reply With Quote
