JRafter,
No need to pay a dealer just to change cams. It's really pretty easy. Only special tool you really need is to change the inner cam bearings just because of where they are and the concequences if they were to fail during installation or removal.
I see you are in Virginia. Got a good bud in VA that has done cams. Ask around .... someone lives close to you that could help you out.
It's a 2 hour job at most just to swap cams. You'll need adjustable pushrods if you aren't going to pull the top.
Cold Rider
"You gotta grow old - you don't have to GROW UP!"
