EFI and wild cams.How big is too big?
Planning a pretty stout build on a 04 EFI Bagger. How wild can you go on the cams before the MAP sensor has issues with the low vacum signal at idle. Is this a real problem or just an anoyance requiring a slightly faster idle?
