Leslie Kay'sSportbikeTrackGearDan Vance RacingPowerstar Sparkplugs
Stainless Ride Specialty AccessoriesDiamond Bar ChoppersBikeBandit
Custom Dynamics
Old 10-31-2004, 07:07 PM   #1 (permalink)
shadow7 is on a distinguished road
transmission oil change
I just changed the transmission oil on my 2000 Fatboy. I used Redline Shockproof. When i checked the level it was too high, so i tryed to drain some out. Nothing coming out drain plug. I know the Redline is thick... but. Did i miss something?
thnaks jim
shadow7 is offline   Reply With Quote
Old 10-31-2004, 09:03 PM   #2 (permalink)
FXDeanX is on a distinguished road
Pull the dipstick out of the fill hole...
FXDeanX is offline   Reply With Quote
Old 11-01-2004, 09:35 AM   #3 (permalink)
Thanks, I did that, but maybe I didn't wait long enough. Shockproof is pretty thick. There is only the one drain plug for the transmission, right?
thanks
Old 11-01-2004, 11:31 AM   #4 (permalink)
TomB is on a distinguished road
Uhhh, Shadow, are you SURE you drained out the tranny and not the primary or crankcase? Level too high, but nothing comes out the drain suggests that you drained one hole and (over)filled another ...
TomB is offline   Reply With Quote
Old 11-01-2004, 12:18 PM   #5 (permalink)
killmeyer000's Avatar
killmeyer000 is an unknown quantity at this point
thanks
yes, there is only one drain plug. it's in between your shocks. perhaps if you start the bike and let it warm up for a few minutes.
killmeyer000 is offline   Reply With Quote
Old 11-01-2004, 12:20 PM   #6 (permalink)
don't start your bike if you are suspicious that this is the case!
Old 11-01-2004, 12:33 PM   #7 (permalink)
Thanks guys, looks like there is allen head drain plug at bottom of crankcase that I thought was the transmission drain. As you mentioned I should have looked up between the shocks for a hex nut. Thanks again
Old 11-01-2004, 02:57 PM   #8 (permalink)
jalexand is on a distinguished road
Go get a service manual for $50, it will be money well spent.
jalexand is offline   Reply With Quote
Old 11-01-2004, 05:35 PM   #9 (permalink)
DILLIGAF
berserker's Avatar
It is money well spent, but doesn't show where the drains plugs are at, very well.
I would double check the engine oil to make sure you didn't drain. Just to be safe.
Old 11-01-2004, 06:18 PM   #10 (permalink)
I have a FLT manual and it shows very clearly there. But I have used a softail manual on my brothers bike, and it has been less than accurate. But again, if you are going to be doing your own work, the $50 will save alot of headaches and money down the road.
Old 04-11-2005, 08:45 PM   #11 (permalink)
Glennhu
Which one is Transmission Drain Plug?
Can anyone tell me which plug is the drain plug on my 2000 Heritage Softail for the Transmission Fluid? I've looked through the manual and the picture is not that clear. Is it a hex head drain plug (regular standard socket type) or is it the star/torx type screw?
I can feel a regular hex head bolt between the shocks which I thought was the transmission fluid drain, but when I went to the Harley Dealer to buy transmission fluid, the parts guy sold me the torx screw type with the teflon tape and said I should replace the plug after changing the transmission fluid.
Can someone help before I screw up?
Glennhu is offline   Reply With Quote
Old 04-11-2005, 08:58 PM   #12 (permalink)
Rumbles
The small torx head is the primary chain drain, it has a brass washer on it, the engine oil and the transmision plugs are larger and have a hex head and an o ring which usually needs to be replaced.
Rumbles is offline   Reply With Quote
Old 04-11-2005, 09:42 PM   #13 (permalink)
Glennhu
Thanks Rumbles... I appreciate your advice.
Old 04-12-2005, 01:01 AM   #14 (permalink)
Seahag's Avatar
Seahag is on a distinguished road
I did this same thing first time out with my FLHT. The service manual didn't show any clear pictures that I could find and I ended up draining the six ounces out of the crankcase....wondering why it overfilled the tranny so quickly led me to look a little harder and thats when I found the plug right up next to the frame rail on the bottom...you have to be damn near completely under the bike to see it if you don't know where you're looking for it.
Seahag is offline   Reply With Quote
Old 04-12-2005, 08:51 AM   #15 (permalink)
jean-luc
I use an old mirror...I put it under the bike, I look in the mirror et voila ! No more problemo to do the job..
I wonder why I never have the right tool to do the job ?
jean-luc is offline   Reply With Quote
