torque needed for wheelie? : V-Twin Forum: Harley Davidson Forums
Old 10-09-2004, 06:09 PM   #1 (permalink)
ratrider wants to know Dino or Syn?
What would I have to do to get my '02' FXDX to pull the front wheel just by twisting the throttle? If you know the total weight and distribution, gearing, etc., I would assume you could calculate the torque needed to lift the front. Maybe I'll try easing the front wheel onto the bathroom scale.
_______________________________________
DOH! NUTTS! Is there nothing they can't do?
ratrider is offline   Reply With Quote Quick reply to this message
Old 10-09-2004, 09:38 PM   #2 (permalink)
Rockbiter's Avatar
Rockbiter wants to know Dino or Syn?
I typed up a two page disertaion on this just now, and then the web site dumped it. Suffice to say, you would need about 150 ft lbs of torque to straight lift the front end by throttle alone. I did all the math, applied the torque multiplying effects of the gearing, etc etc. (630 lb bike, no rider) That assumes perfect traction, zero loss transmission, etc. add mass near the rear axle, and the numbers start dropping quick, put the GF over the rear axle, and she'll be punching you in the kidneys in no time...
A stock bike will not do it (mathmaticly speaking), but put out about 100 ft lbs of torque, with a center of balance close to the rear axle, and you are skyborn in no time!
'04 TC103 FXD
SE 4.375" Stroker Crank
SE 3.875" Flat top Pistons
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE 6200 RPM Ignition module
SE Clutch spring
White Bros E-Z clutch release
LMR2 oil pressure spring
Rockbiter is offline   Reply With Quote Quick reply to this message
Old 10-09-2004, 09:49 PM   #3 (permalink)
Seahag's Avatar
Seahag wants to know Dino or Syn?
Lets not forget slipping/dropping the clutch...I talked to a guy who would wheelie his electra glide (stage I only)...he told me the trick was to dump the clutch over 4000rpm. This guy was an old motorcrosser and would wheelie everything. I'd never try it on my glide.
Seahag is offline   Reply With Quote Quick reply to this message
Old 10-10-2004, 02:36 AM   #4 (permalink)
Known Associate
Mad Dog's Avatar
Mad Dog wants to know Dino or Syn?
On a special done by the Discovery Channel on Corbin Seats, they showed an Ultra Classic, yeah, the fully dressed one with all the fairings, tour pack, etc. pull a throttle only wheelie (no rev the motor, pop the clutch) for about 35-40 ft. !
I don't know the specifics of the motor build up, etc. but it was very impressive....
1990 FATSTER - 16" wheels front/back, Fat-Bob tanks/dash, Koni shocks, Ness taildragger fenders, Ness wide-glide billet trees, Storz steering dampener, PM calipers, full-floater rotors, SBS brake pads, Fat-Boy lights, 1200 10:1 pistons, Total Seal Gapless rings, Andrews V6 cams, Crane adj. pushrods, mod. CV carb., custom Ram-Air filter, Crane Single-Fire, Accel coils, Thunderheader (from Sonny Barger), Barnett Extra-Plate clutch, Balance Master, Jagg oil cooler, Spyke Krank Vent,....
Mad Dog is offline   Reply With Quote Quick reply to this message
Old 10-10-2004, 04:07 AM   #5 (permalink)
Cryptoboy's Avatar
Cryptoboy wants to know Dino or Syn?
Easiest and cheapest way....go buy a Suzuki GSX-R 1000! (you might be able to save a few grand and get the 600 instead!)
Actually one of the parts guys at the local dealer has an FXDX and he is able to pop a wheelie just about anytime, although he's pretty secretive and tends to avoid the subject when we ask him what he modified.......
No, I will not fix your computer.
GO NOLES!!!!!
Cryptoboy is offline   Reply With Quote Quick reply to this message
Old 10-10-2004, 05:10 PM   #6 (permalink)
Rockbiter's Avatar
I think the easiest way would be to change the gearing lower (the secret way would be to use a smaller diameter engine sprocket)
Other than that, doing the typical stage one mods, with cams and maybe head porting should be enough to do it without going cost-overboard. Stiffen up the rear suspention to maximize appied torque. Stickier tires. The Dunlops are too hard IMHO.
Wow, the more i think about this, the more i wanna find out...
'04 TC103 FXD
SE 211 cams
SE A/C
SE 2 Slip-Ons
SE Clutch spring
