Too fast of an idle-efi...Help!
Hello,
I have a 2004 FXDL/I with V&H Bigshot staggerds as the only mod to the bike so far. I did not get the remap done, since it seems to be running smooth so far, and the plugs look farily normal. My problem though is that about 1 out of every 5 or so cold starts, the engine shoots up to a idle speed of around 2400-2900 rpm's right away, and will stick there for about 10 seconds, then it will drop like a rock down to about 1100 rpm's for a little bit longer until it sinks into the normal 1000 rpm warm idle. The bike runs fine otherwise, but this concerns me because I was starting the bike when the tempature was in the 30's and it did not do this, and now I start it in the 50-60 degree temps and it will idle extremely high. Does anyone out there know what this problem might be? Has anyone had this problem, and what did you do to fix this? My bike is under warranty but I'm worried that they might not try to cover it because I added the aftermarket exhaust. Do you think that might be a problem?
